Edge Software Catalog
488 Discussions
[Tofino Switch]There is no response when the qsfp cable inserted into the server
jmt
When I use a cable to connect the Wedge 100B Switch  and server, there is no response.
In Wedge 100B Switch, OPR is DOWN, as follows:
bf-sde> pm show
PORT |MAC |D_P|P/PT|SPEED |FEC |AN|KR|RDY|ADM|OPR|LPBK |FRAMES RX |FRAMES TX |E
1/0 |23/0|132|3/ 4|100G |NONE|Au|Au|YES|ENB|DWN| NONE | 0| 0|
2/0 |22/0|140|3/12|100G |NONE|Au|Au|YES|ENB|DWN| NONE | 0| 0|
In my server,  no link , why ? I've plugged in the cable。
xxxx@xxxxx~> ethtool p4p2
JesusE_Intel
Hi jmt,
Are you running into this issue when setting up a software package from Edge Software Hub? If so, could you please share which software package and a link to the documentation that you are following?
Jesus
JesusE_Intel
Hi jmt,
Jesus
JesusE_Intel
