Edge Software Catalog
471 Discussions
can't import training module
fa2233
i copy the pcb file and rename it name also rename all the file under it  and change some content  to produce another module. the EIS still can't  recognize it as a module
Jia-Shing_W_Intel
Did you rebuild the ia_video_analytics Docker image? As the model files are copied into the image at build time, it takes a rebuild to add new ones to a container.
fa2233
fa2233
the ia_video_analytics and ia_video_ingestion has the COPY python floder cmd but  i use ls command  find out that the udfs/python floder not update,don't contain new module
i copy the udfs/python floder to /IEdgeInsights/VideoIngestion and /IEdgeInsights/VideoAnalytics floder and add
"COPY udfs ./common/udfs "
"RUN ls ${GO_WORK_DIR}/common/udfs/python"
two cmd to ia_video_analytics and ia_video_ingestion dockerfile  and now it works
how to slove this without copy this file by myself
Jia-Shing_W_Intel
Do you happen to have DOCKER_REGISTRY set in .env and have images with the same name tagged both locally as well as on the registry?
REPOSITORY TAG IMAGE ID CREATED SIZE
localhost:5000/ia_video_analytics 2.2 367332056d5d About a minute ago 3.87GB
localhost:5000/ia_common 2.2 98d78122bfdd 6 minutes ago 1.7GB
localhost:5000/ia_data_analytics 2.2 71dde396d2f1 2 hours ago 2.04GB
localhost:5000/ia_dc 2.2 8b5a8f83c8a2 2 hours ago 2.75GB
localhost:5000/ia_influxdbconnector 2.2 b474f0541df7 2 hours ago 1.95GB
localhost:5000/ia_telegraf 2.2 3929d999f8ec 2 hours ago 1.77GB
localhost:5000/ia_grafana 2.2 1e3972270cf6 2 hours ago 1.75GB
localhost:5000/ia_visualizer 2.2 92f4bd81b431 2 hours ago 1.9GB
localhost:5000/ia_video_ingestion 2.2 b672beffe16a 2 hours ago 5.5GB
localhost:5000/ia_etcd_ui 2.2 3285d4431468 2 hours ago 1.63GB
localhost:5000/ia_openvino_base 2.2 562d6f93d5c6 2 hours ago 3.52GB
localhost:5000/ia_eisbase 2.2 abaa0e336fdc 2 hours ago 1.51GB
ia_visualizer 2.2 2f0b68d75912 10 days ago 1.9GB
ia_data_analytics 2.2 2f1d0abf162e 11 days ago 2.04GB
ia_dc 2.2 872e0382abb1 11 days ago 2.75GB
ia_influxdbconnector 2.2 3356b0de1e21 11 days ago 1.94GB
ia_telegraf 2.2 80098e4a861d 11 days ago 1.77GB
ia_grafana 2.2 19efa3db5a4e 11 days ago 1.75GB
ia_video_analytics 2.2 10771f2fca48 11 days ago 3.87GB
ia_video_ingestion 2.2 a16c3d05c636 11 days ago 5.47GB
ia_etcd_ui 2.2 b08456859e27 11 days ago 1.63GB
ia_openvino_base 2.2 60026d4595a2 11 days ago 3.51GB
ia_common 2.2 a3ad79621dc0 11 days ago 1.7GB
ia_eisbase 2.2 3a32db9da4e7 11 days ago 1.51GB
ia_etcd_provision 2.2 0ff4f3a0e1f6 11 days ago 260MB
ia_etcd 2.2 dd130a5bb288 11 days ago 248MB
ubuntu 18.04 2eb2d388e1a2 3 weeks ago 64.2MB
registry 2 2d4f4b5309b1 8 weeks ago 26.2MB
python 3.7-slim 7e61acc68112 6 months ago 179MB
The problem is, it is expected to have this "DOCKER_REGISTRY: ${DOCKER_REGISTRY}" args in each and every service in docker-compose.yml like below. Somehow, it is missing.
ia_eisbase:
  build:
    context: $PWD/../common
    dockerfile: $PWD/../common/dockerfiles/Dockerfile.eisbase
    args:
      UBUNTU_IMAGE_VERSION: ${UBUNTU_IMAGE_VERSION}
      EIS_VERSION: ${EIS_VERSION}
    image: ${DOCKER_REGISTRY}ia_eisbase:${EIS_VERSION}
Because of this, each time you rebuild the images, Docker actually use the local ia_common image to supply the common/udfs directory, which is out of date and doesn't contain the new model files you added.
I'll let the developers know and make sure it's fixed in a coming release. In the meantime, please manually add this DOCKER-REGISTRY argument in each services, like my attachment. Good catch and sorry about the inconvenience.
Jia-Shing_W_Intel
Correction: for ia_eisbase, you don't need this DOCKER_REGISTRY argument. It's needed only for ia_common and other services.
