Edge Software Catalog
445 Discussions
failed to create new application in azure IOT central
jpei_ng
I failed to create new application when I try to use Azure to support over-the-air updates and to enable cloud-to-edge manageability of application services.
Attached is the capture log.
Murni_J_Intel
Hi @jpei_ng
We are currently looking into this issue and I will update you as soon as possible.
jpei_ng
WengWai_C_Intel
Hi @jpei_ng ,
There is a change of the Azure IOT Central template from the CSP that causing the default template in the Manageability component from EII is not compatible. This will be addressed in the coming new EII release around Jan'21. For now, you can use Telit or Thingsboard to setup the Manageability component.
thanks!
Murni_J_Intel
Hi @IvoryHoward
Yes, it is being fixed with the latest release.
May I know what version EII do you use to perform this and is it you still observing the same issue?
