Edge Software Catalog
486 Discussions
failed to install edge insight industrial
MohitSingh
MohitSingh
Hi, yes i am able to install it now and after installation video streaming can also be seen, but unable to access webUI, there is lot mentioned in userguide which I think, I am unable to follw properly.
Jia-Shing_W_Intel
That's great news! I'm glad things work out for you.
Is your VM networking running in Network Address Translation mode? Perhaps its added complexities caused the issue. I use bridging mode.
About the webUI you were not able to access, is it the ETCD web UI? Please make sure the ia_etcd_ui container is running and access it on port 7070, for example, http://localhost:7070/etcdkeeper/.
Please feel free to create a new inquiry here if you need additional help. Take care.
MohitSingh
Yes, I was using NAT which was  causing issue, now I am using Bridging mode.
Jia-Shing_W_Intel
Thank you for confirming my hypothesis. If others encounter a similar issue with their VM-based environment in the future, we will know what to suspect!
