Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
930 Discussions
Arm tool for XL710/I350 and CFG ID for4x10Gbe fiber module application
Anchor
I have an Arm based board with XL710/i350.
is there any eepromarm tool for XL710/I350?
and if config XL710 to 4x10Gbe optical port and directly connect to external fiber module,which cfg ID should be selected?
Caguicla_Intel
Hello Anchor,
Thank you for posting in Intel Ethernet Communities. Your query will be best answered by our Embedded Support team, we will help you to move this post to the designated team. Please feel free to contact us if you need assistance from Ethernet support team.
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
CarlosAM_INTEL
Hello, @Anchor​:
The Intel I210, I211, and X550 EEPROM Access Tool (EAT) document # 572162 is the one that may help you. You should use the proper Intel(R) Ethernet Controller i350 device id in the code. The device id values are listed in answer to question 9, on page 6 of the Intel(R) Ethernet Controller i350 Frequently Asked Questions (FAQs) that can be found at:
https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i350-faq.pdf
The cited tool is accessible to you when you are logged into your Resource & Design Center (RDC) privileged account at the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/572162.htm
The RDC Account Support form is the channel to process your account update request. It can be found at:
https://www.intel.com/content/www/us/en/forms/design/contact-support.html
@Mæcenas_INTEL​.
