Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
918 Diskussionen
Cannot find "513655-i210-i211-production-images"
YuxiaoJi
Einsteiger
11.455Aufrufe
Hi:
I'm using I210-AT chip, and I need to flash the image into the externel flash. But I cannot find the 513655 images mentioned in the "ethernet-controller-i210-i211-faq", can you send me the download link or the images please? Many thanks!
BR,
Yuxiao
1 Lösung
CarlosAM_INTEL
11.412Aufrufe
Hello, @YuxiaoJi:
You can find the Intel® Ethernet Controller I210 and I211- AT Production NVM Images document # 513655 when you are logged into your Resource and Design Center (RDC) privileged account on the following website:
https://cdrdv2.intel.com/v1/dl/getContent/513655
You should fill out the form stated on the following website when you have problems with the provided website or want to update your RDC account:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
Lösung in ursprünglichem Beitrag anzeigen
17 Antworten
CarlosAM_INTEL
11.413Aufrufe
Hello, @YuxiaoJi:
@CarlosAM_INTEL.
YuxiaoJi
Einsteiger
11.399Aufrufe
Hi @CarlosAM_INTEL :
Thanks a lot! I've got the images
BR,
Yuxiao
CarlosAM_INTEL
11.390Aufrufe
Hello, @YuxiaoJi:
We are glad that our previous communication is useful.
Please do not hesitate to contact us again if you have any questions related to Intel Embedded devices.
@CarlosAM_INTEL.
CvCharlieMynott
Einsteiger
10.997Aufrufe
Hi Carlos
I've used the #513655 document for copper connection (TBase1000 via magnetics and CAT5). Is there a different configuration file for backplane mode connection (802.3ap / 1000 Base KX) ?
Additionally, we have had to reduce the speed of the copper designs to 100 Base T.  Could you confirm that the MDI_MINUS and MDI_PLUS ports are voltage driven, require no pull-ups and that the centre tap of the magnetics should not be connected to a bias voltage? (In order to get the design to work, we have had to connect MDI ports to +3V3 via 50 ohm resistors and connect the magnetic centre tap to 3V3).
Schematic attached
charlie.mynott@crystalvision.tv
Charlie
CarlosAM_INTEL
10.984Aufrufe
Hello, @CvCharlieMynott:
We sent an email to the address associated with this account with suggestions that may help you.
You should know that this is a public place, where you should avoid include private or confidential information, such as your business email address or information cover by NDAs.
@CarlosAM_INTEL.
hori
Einsteiger
10.243Aufrufe
Hello.
cannot access
it says "Not Authorized to Access".
what's the problem?
CarlosAM_INTEL
10.215Aufrufe
Hello, @hori:
You need to have a Resource and Design Center (RDC) privileged account to have access to more documents that may help you on the provided website.
The RDC Account Support form is the channel to process your account update process by filling out the form stated on the following website:
You should use a business email address to evade any inconvenience. Please avoid the free email provider's address (such as the provided by Hotmail, Gmail, Yahoo, or others).
@CarlosAM_INTEL.
Jesonwang
Einsteiger
9.148Aufrufe
Hello @CarlosAM_INTEL :
Have you resolved the relevant issue yet.If yes,can you give me the Documents for my email-Address 554911643@qq.com.Thank you very much.
cae0n
Einsteiger
9.009Aufrufe
Hi Carlos,
Thank you for providing the links to the I210 and I211 production images.
I'm struggling to find the production images for the i226, can you provide a link to those please?
Thank you,
CarlosAM_INTEL
8.998Aufrufe
Hello, @cae0n:
The information that may help you is stated in the following website:
https://www.intel.com/content/www/us/en/products/details/ethernet/gigabit-controllers/i226-controllers/docs.html
@CarlosAM_INTEL.
cae0n
Einsteiger
8.911Aufrufe
Carlos,
This webpage you linked to does not have any production images for the i226.
There is a guide for using the EEPROM access and a datasheet for the i226 but there are NO images!!!
I need an image to program in my i226-IT units! Where can I find these images???
For example the i210 images are here: http://www.intel.com/cd/edesign/library/asmo-na/eng/513655.htm
now where are the i226 images?!?
I just want to program my i226!!!! why is this so difficult???
Thank you,
Cameron Bolton
Diego_INTEL
8.909Aufrufe
Hello @cae0n,
I'm truly sorry for the troubles.
You may check the document #686540 - Intel® Ethernet Controller I226 NVM
https://www.intel.com/content/www/us/en/secure/content-details/686540/intel-ethernet-controller-i226-nvm.html
Please, let me know if this is enough or if you need anything else.
@Diego_INTEL
cae0n
Einsteiger
8.850Aufrufe
Hi Diego,
That is very helpful; thank you very much.
Unfortunately it doesn't resolve my problem.
My i226 has the following PCI IDs:
Vendor: 0x8086
Device: 0x125F
The binaries you supplied seem to only be valid for 0x125B, 0x125C, 0x125D device IDs. Do you have a version of the image for the 0x125F device?
Sincerely,
Cameron Bolton
Diego_INTEL
8.847Aufrufe
Hello @cae0n,
You are very welcome and yes, 0x125F is because is blank, according to the datasheet, document #596659, in page 28:
Yours is I226-IT correct? You may use the image 0x125D.
Also, document #574707 - Intel® Client Ethernet Message of the Week (Intel I219, I225, I226), has further information regarding the documentation for these controllers, it may be helpful for you to have and the datasheet.
@Diego_INTEL
cae0n
Einsteiger
8.822Aufrufe
Hi Diego,
Again, thank you for the tremendously helpful info.
Can you link to this "#574707 - Intel® Client Ethernet Message of the Week (Intel I219, I225, I226)" document? I cannot seem to find it anywhere.
Also, yes our i226 is specifically an i226-IT.
I'm able to write the binary file you provided (specifically FXVL_125D_IT_2MB_2.22.bin) to the "Shared Flash" and I get the "Shared Flash Image updated sucessfully" message.
I then completely power cycle the board. However, my i226 is still not operating, in fact nothing has changed.
It still shows up in the eeupdate utility as an empty flash and device manager still shows it as not having a driver.
I uploaded two screenshots to this post. One shows me programming the binary file into the shared flash, and the other shows the i226 device still not loaded in device manager after power cycling the system.
Can you tell me if I'm doing anything wrong in my programming procedure based on my screenshot? I am following all the steps I can find online.
Do you have any additional documentation on the process for updating the flash on the i226?
Thank you,
Cameron Bolton
Diego_INTEL
8.808Aufrufe
Hello @cae0n,
Oh, sometimes the tool doesn't do anything, and must try again. Can you try with the following commands, I hope this helps.
$ cp ../../FXVL_125D_IT_2MB_2.22.bin firmware
$  ./eeupdate64e /nic=1 /data firmware
Edit: I forgot to add you the link.
https://www.intel.com/content/www/us/en/secure/content-details/574707/intel-client-ethernet-message-of-the-week.html?DocID=574707
About the EEupdate, only the txt file that comes in the document #615722
@Diego_INTEL
Diego_INTEL
9.107Aufrufe
Hello @Jesonwang,
What is the issue that you have?
Also, we can't share any restricted documents. If you need any documentation from RDC that is confidential, you will need a Premier account in order to get access to them. The links that are shared in this Forum required the Premier account first.
You can check this link if you need further information:
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
My apologies for the inconvenience.
@Diego_INTEL
Antworten
