Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
EEPROM Access Tool (V 0.7.9) I211 Flash in UBUNTU18.04 for Tegra (ARM64, r32.4.2, Jetson Xavier NX)
Eepromaccesstool 0.7.9 Dump error message "Check command open to write error" appears, the dumped OTP file is empty 0, the previous OTP burning back will also cause an error.
Highlighted
Re: EEPROM Access Tool (V 0.7.9) I211 Flash in UBUNTU18.04 for Tegra (ARM64, r32.4.2, Jetson Xavier NX)
Hello, @RChua1​:
We have contacted via email to help you.
@Mæcenas_INTEL​.
Highlighted
We did not receive the email, maybe it was filtered by the MIS server.
 For questions about the "Check command open to write error" message, please send an email to tom.lin@gigabyte.com.
thanks.
Highlighted
Hello, @RChua1​:
Thanks for your update.
We have sent again the email.
@Mæcenas_INTEL​.
Highlighted
After the first successful refresh, we will not be able to refresh and change the MAC again.
Check the document "ethernet-controller-i210-i211-faq.pdf"  2.15 / 2.24.
How to change "iNVM word address 0xA, bit 15 is set to 1b"?
Check the document "I211-Ethernet Controller-datasheet.pdf" 3.2.3, How to enable "SECURITY_EN"?
We have tried to pull pin12 down but the result is the same.
Thank you.
https://community.intel.com/t5/Embedded-Connectivity/EEPROM-Access-Tool-V-0-7-8-not-working-for-prog...
https://community.intel.com/t5/Embedded-Connectivity/EEPROMARMTOOL-only-can-flash-I210-for-one-time-...
Highlighted
Hello, @RChua1:
Could you please clarify if you follow the suggestions that we provided in our previous email?
@Mæcenas_INTEL
Highlighted
Hi @Mæcenas_INTEL
We still haven't received a letter from the company's mailbox.
If the flash has the wrong hex, how to flash back?
thanks.
Highlighted
Hello, @RChua1:
Thanks for your reply.
Based on the information provided to you the past June 22nd, 2020, we have sent a private message through this tool with the suggestion that we have provided to the email register on your profile for this forum.
@Mæcenas_INTEL
Tags (2)
Highlighted
Hi @Mæcenas_INTEL
  Sorry, after the Community update, the email disappeared.
After we try to replace nVIDIA NX with nVIDIA Jatson NANO processor, we can successfully flash (attached picture).
Highlighted
Hello, @RChua1:
Please follow our suggestion provided via the private message of this portal sent by us.
@Mæcenas_INTEL.
