Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
915 Discussions
EEPROM Access Tool (V 0.7.9) I211 Flash in UBUNTU18.04 for Tegra (ARM64, r32.4.2, Jetson Xavier NX)
RChua1
Hi
  Eepromaccesstool 0.7.9 Dump error message "Check command open to write error" appears, (nvidia01-1.jpg)the dumped OTP file is empty 0.
If the flash has the wrong hex file, how to flash back?
Check the document "ethernet-controller-i210-i211-faq.pdf" 2.15 / 2.24. How to change "iNVM word address 0xA, bit 15 is set to 1b"? and Check the document "I211-Ethernet Controller-datasheet.pdf" 3.2.3, How to enable "SECURITY_EN"?
We have tried to pull pin12 down but the result is the same.
After we try to replace nVIDIA NX with nVIDIA Jatson NANO processor, we can successfully flash (nano-01.jpg).
After the community’s private message was updated in July, we did not read any more messages,
If you must use private messages, please attach email:   <removed>
RChua1
hello @idata
  Can you help? We follow the suggestions to find Springville product, software/Driver/OS case category and Tool case Subcategory. The closest thing is this community, and it seems that there is no response.
Best Regards
AlfredoS_Intel
Hi Rchua1,
Thank you providing those information.
Please allow us some time to check on this.
We will get back to you no later than 3 business days from now.
Alfred S
Intel® Customer Support
AlfredoS_Intel
Hi Rchua1,
To aid us in checking your concern, please provide us the result of this command:
ethtool -i xxxx where xxx is the field that the card is assigned to
Alfred S
RChua1
您好AlfredoS
最好的祝福,
beauty777
大陆不能上社交网站!比如;Twitter  Facebook   google
AlfredoS_Intel
Hi
Alfred S
RChua1
Hi @AlfredoS_Intel
  Are there any updates? Did you find this problem?
The i211 network chip is on the carrier board of this product.  https://developer.nvidia.com/embedded/jetson-xavier-nx
AlfredoS_Intel
Hi Rchua1,
Thank you for waiting for our update and for sharing the additional information:
While we were checking, these questions came in to mind which will help us find a recommendation for your issue:
  1. May we know the firmware version that you are updating the network adapter to?
  2. May we know the model of the board that you are using?
  3. Is the network cards embedded on the board design?
We look forward to your reply. Should we not get your reply, we will follow up after three business days.
Alfred S
RChua1
Hi @AlfredoS_Intel
  Thanks for your response.
1.i211 only update HEX format file and MAC address, no FW.
2.Carrier board model:EPG.
3.ARM NX PCIE signal to I211 on the carrier board.
AlfredoS_Intel
Hi Rchua1,
Thank for your quick reply.
We will take note of the information that you have shared.
We will continue to investigate on the issue.
We will strive to provide you with an update no later than Tuesday, August 4, 2020
Many thanks for viewing this message.
Have a wonderful day!
Alfred S
RChua1
Hi @AlfredoS_Intel
  Hope that good news and results will happen.
RChua1
AlfredoS_Intel
Hi RChua1,
Please allow us more time to check on this.
Alfred S
AlfredoS_Intel
Hi RChua1,
While we are investigating, we just want to confirm, are you trying to flash the PCI option ROM of the network adapter.
Looking forward to your reply. Should we not get your reply, we will follow up after 3 business days.
Alfred S
RChua1
Hi  @AlfredoS_Intel
  Run the eepromaccesstool079 program, and an error message appears (please refer to the attachment nvidia01-1.jpg for the issue on 7/16)
  Later, we also tried flash HEX-files, flash MAC, and of course the same error occurred. (nvidia01.jpg)
RChua1
Hi @AlfredoS_Intel
  Are there any updates? We tested that the old nVIDIA processor NANO can be used with i211 to flash normally, and the problem was discovered after replacing the NX launched this year.
AlfredoS_Intel
Hi Rchua1,
We appreciate your patience in waiting for an update.
After reviewing your concern, we have confirmed that we have a forum for these kinds of issues and we will moving it to that ‘Forum’ so it can get answered more quickly.
Please wait for their reply within 1 to 2 business days.
Alfred S
RChua1
Hi @AlfredoS_Intel
  Are there any updates?  Or who is responsible for this issue?
Best Regards
CarlosAM_INTEL
Hello, @RChua1:
Based on the information provided you in the following forum, could you please clarify if you have followed our suggestion?
https://community.intel.com/t5/Embedded-Connectivity/EEPROM-Access-Tool-V-0-7-9-I211-Flash-in-UBUNTU18-04-for-Tegra/td-p/686598
We are waiting for your clarification.
@CarlosAM_INTEL.
RChua1
hi @CarlosAM_INTEL  & @AlfredoS_Intel
  We have followed your suggestions, but there is no solution, and july 17 Browse Forums has no suitable place to send flash tool problems.
At the beginning, we asked "Eepromaccesstool 0.7.9 error message" in "Embedded Connectivity", june 19 You sent the letter
"it should be created using the Springville product, Software/Driver/OS Case Category, and Tool Case Subcategory."
We received the letter on july 17 and looked for the closest community.
We follow the suggestions to find Springville product, software/Driver/OS case category and Tool case Subcategory. The closest thing is "Software Products community",
Finally in August 14, the question was transferred to "FPGAs and Programmable Solutions" and now it was transferred back to "Embedded Connectivity",
We don’t know why we switched to "Embedded Connectivity". We can’t transfer this letter. We need to send the question again in "FPGAs and Programmable Solutions"?
  Please do not use Private Messages, because we cannot receive any messages, If you must use private messages, please attach email:   <removed>
