Hello, @RChua1:
We have contacted via email to help you.
We did not receive the email, maybe it was filtered by the MIS server.
For questions about the "Check command open to write error" message, please send an email to <removed>.
thanks.
After the first successful refresh, we will not be able to refresh and change the MAC again.
Check the document "ethernet-controller-i210-i211-faq.pdf" 2.15 / 2.24.
How to change "iNVM word address 0xA, bit 15 is set to 1b"?
Check the document "I211-Ethernet Controller-datasheet.pdf" 3.2.3, How to enable "SECURITY_EN"?
We have tried to pull pin12 down but the result is the same.
Thank you.
Hello, @RChua1:
Thanks for your update.
Could you please clarify if you follow the suggestions that we provided in our previous email?
Hi @CarlosAM_INTEL
We still haven't received a letter from the company's mailbox.
If the flash has the wrong hex, how to flash back?
thanks.
Hello, @RChua1:
Thanks for your reply.
Based on the information provided to you the past June 22nd, 2020, we have sent a private message through this tool with the suggestion that we have provided to the email register on your profile for this forum.
Hi @CarlosAM_INTEL
Sorry, after the Community update, the email disappeared.
After we try to replace nVIDIA NX with nVIDIA Jatson NANO processor, we can successfully flash (attached picture).
Hello, @RChua1:
Please follow our suggestion provided via the private message of this portal sent by us.
after the Community update, the email disappeared. Can you resend it to us?
Best regards
Hello, @RChua1:
We have resent the communication in a private message through the community. It happened the past July 9th, 2020 as we mentioned in our previous communication, also you may confirm it in the attached screenshot specifically in the yellow-highlighted information.
Hi @CarlosAM_INTEL
Due to the update of the intel community, all messages in private messages disappeared (20200715.jpg).
The same platform/OS uses EEPROM Access Tool (V 0.7.9),
nVIDIA Jetson NANO can be updated. If you change to Xavier NX, an error will occur, where is the problem?
Hello, @RChua1:
Thanks for your clarification.
We have sent again the private message as you may notice in the attached screenshot specifically in the yellow-highlighted information.
We have confirmed many times that it is the same "no messages",
There is no yellow-highlighted information(20200716.jpg).
Our department has tried this problem for a long time, Must read this private message?
Hello, @RChua1:
Based on your profile information, we have sent again our communication to the address stated on it.
By the way, to avoid delays we have to follow your June 22th, 2020 request.
