Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
891 Discussions
Gigabit Adapter limited to 100mbps
Schan721
Hi Intel,
We did a board that uses SOC(Debian GNU) integrated with the Intel's CT-Desktop adapter(82574l).
It got connected and worked.But we had issues in terms of actual speed when we tried using the PCI card at Gbps.
It automatically switched to 100mbps failing to run at the desired gigabit speed.
Is there any specific drivers to be pre-installed into the chip to work at gbps?
We could share a part of the schematics where 82574l is integrated with SOC.
Thanks in advance.
Saravana
CarlosAM_INTEL
Hello, Saravana_CSB :
In order to be on the same page, could you please confirm us if this thread is related to the device mentioned at the following document?
https://www.intel.com/content/dam/doc/product-brief/gigabit-ct-desktop-adapter-brief.pdf https://www.intel.com/content/dam/doc/product-brief/gigabit-ct-desktop-adapter-brief.pdf
Waiting for your reply.
Carlos_A.
Schan721
Hi Carlos
Thanks for the response,
Yes, This is correct,
I have also attached a detailed info of the problem. If you need more details please let us know.
Saravana
CarlosAM_INTEL
Thanks for your reply.
Based on your previous communication, could you please tell us if the affected design has been developed by you? Because you told us that the device related to this situation is an https://ark.intel.com/products/50395/Intel-Gigabit-CT-Desktop-Adapter Intel(R) Gigabit CT Desktop Adapter that is not equal to the showed in the attached document.
Waiting for your clarification.
Carlos_A.
kore
Dear CAgui2,
I am currently having somewhat similar issue with Intel(R) Gigabit CT Desktop Adapter.
For most cases, this network card successfully auto-negotiate at the speed of 1Gbps.
But for some link partners (Such as 10G Network card and etc..) , this network card fails performing auto-negotiation and no link fails.
if I set Intel(R) Gigabit CT Desktop Adapter speed to 1Gbps fixed, the result is same.
Only when when i set Intel(R) Gigabit CT Desktop Adapter speed to 100Mbps, Link is up.
Please guide me how to make 1Gbps link with Intel(R) Gigabit CT Desktop Adapter and other 10G network card.
Thank you.
Jun Han
CarlosAM_INTEL
Hello, @3000017698951.5317936574007397E12​ :
Your consultations related to Ethernet Adapter [such the Intel(R) Gigabit CT Desktop Adapter] should be addressed to the Intel(R) Ethernet Forum that can be found at the following website:
https://forums.intel.com/s/topic/0TO0P00000018NbWAI/intel-ethernet
@Mæcenas_INTEL​.
