Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
889 Discussions
I219-LM no yellow bang but not work (Comet Lake-S)
Nash1
Hi
We used i219 and i210 at our project, but only i210 can work now.
After plugin lan cable, we can see i219 connection state is Ethenet at windows "New work and Sharing Center" as attached fig Lan_i219.jpg.
We try to ping i219 after setting fix IP, but it always shows Destination host unreachable.
However, i210 works fine when use the same method to test (Lan_i210)
                                   ping
PC (192.168.0.1)       <----->     Test Platform use I219  (192.168.02)
Result: Reply from 192.168.0.2: Destination host unreachable.
                                   ping
PC (192.168.0.1)       <----->     Test Platform use I210 (192.168.03)
Result: Reply from 192.168.0.1: bytes=32 time=2ms TTL=128
Does anyone have idea about this issue?
Please advise.
Thank you.
OS: Win10 IOT
CPU:Comet Lake - S
Lan_i219.jpg.
Lan_i210
Caguicla_Intel
Hello Nash1,
We will be glad to check your request but before we proceed, kindly provide following information that would help with the investigation.
1. Can you more details on your project when you mentioned, 'we used i219 and i210 at our project, but only i210 can work now.'?
2. Model of the motherboard used
3. Are these newly purchased system?
4. Are you able to establish connection on your I219 controller? Can you browse the internet using your system with I219?
5. Do you get any error when connecting the cable on your system? If you do, please share the exact error message with us.
6. Can you share if your Firewall is disabled on any of your systems with I210 and I219 controller?
7. What are the troubleshooting steps done so far?
8 Please provide the System Support Utility (SSU) log of your 2 systems. This will allow us to check your Adapter details and configuration. Kindly refer to the steps below.
a- Go to https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
b- Open SSU.exe
c- Mark the box "Everything" and then click "Scan".
d- When finished scanning, click "Next".
e- Click on "Save" and attach the file to a post.
Awaiting to your response.
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Intel® Customer Support
Nash1
Hi Crisselle
=>  Our porject has two lan, one is I210IT , and the other is  I219LM.
       While plug in LAN cable, only I210IT can browse the internet.
    We use Comet Lake-s with PCH-H W480.
    The system is built by our team.
    =>Yes, I can establish connection on I219 controller, please see below.
=> I cannot browse the internet using our system with I219
=>We don't get any error message when connecting the cable on our system.
=> The Firewall is already disabled.
  I. Our Hardware team already checked the schematics about LAN and the schematics is correct.
      The schematics was refer to the other project which also used I219 controller and it is workable.
  II.We try to use another PC to ping i219-LM but fail.
  III.Try different version ME/GBE/Lan driver.
a- Go to https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91...
b- Open SSU.exe
The driver is download form the link.
Intel® Ethernet Adapter Complete Driver Pack
Version. 27.2.1
(Virus scan in progress ...)
Caguicla_Intel
Hello Nash1,
Thank you for the detailed and prompt reply.
Just a clarification, when you mentioned 'The system is built by our team', can you confirm if your team designed or customized your own board? If yes, we may need to move the thread to the concerned team so they can assist you further.
Hoping to hear from you soon.
Crisselle C.
Nash1
Hi Crisselle
Yes. We need more help.
Caguicla_Intel
Hello Nash1,
Thank you for the prompt reply.
Since your query involves customization, please be informed that this will be best answered by our Embedded Connectivity Support team. We will help you to move this post to the designated team for further assistance. Please feel free to contact us if you need assistance from Ethernet support team.
Have a nice day and stay safe!
Crisselle C.
CarlosAM_INTEL
Hello, @Nash1:
We sent an email to the address associated with this account with information that may help you.
@CarlosAM_INTEL
