Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
881 Discussions
I225/I226 Signal Measurement
Daedalus
Because we are not x86 Base, we cannot use the tools you currently provide for signal measurement
platform : NVIDIA AGX ORIN (ARM)
OS : UBuntu 20.04
LAN : I225-TI
Is it possible to provide
615722-I225-I226-LAN-Tools-WW40-22
We need information in I225-I226-Lanconf_TestPattern_Scripts
Caguicla_Intel
Hello Daedalus,
Can you confirm if your inquiry involves customized board? If yes, we need to route your query to the concerned team for further assistance. If no, please share more information on your intended configuration for us to further check your query.
We look forward to your reply.
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Intel® Customer Support
Daedalus
Dear Sir  ,
         This is our standard
          PM : Anita
          SRD : Gary & Anson
          ERD : Daedalus
          NVIDIA Jetson AGX Orin is Arm Cortex A78AE Architecture module.
          The operating system is UBuntu 20.04.
          We use the PCIe interface of NVIDIA Jetson AGX Orin to communicate with Intel I225-IT.
          Because we want to measure the signal quality of I225-IT, but the current tool only supports x86.
          How do we need to set up to get the required test signal?
Caguicla_Intel
Hello Daedalus,
Thank you for the swift reply.
When you mentioned 'Because we want to measure the signal quality of I225-IT, but the current tool only supports x86.', can you share which tool are you referring to? Please provide the name of the tool so we can further check your request.
Hoping to hear from you soon.
Should there be no response from you, we will follow up after 3 business days.
Crisselle C.
Daedalus
Dear Sir ,
    There are 2 ways to generate IEEE Test Patterns for Foxville I225 I226
    1. EthAgent tool
    2. Lanconf (UEFI Shell Command
    Please refer to Annex
Caguicla_Intel
Hello Daedalus,
Appreciate your prompt reply.
Please be informed that we removed the attached documentation since it is Intel Confidential and can only be access with CNDA.
Can you share the model of the motherboard where the I225 was embedded to?
Awaiting to your reply.
Crisselle C.
Daedalus
Dear Sir ,
    Our product name is 52-THKMLB1-Z1B
Caguicla_Intel
Hello Daedalus,
Good day!
Please be informed that this will be best answered by our Embedded Connectivity Support team. We will help you to move this post to the designated team for further assistance. Please feel free to contact us if you need assistance from Ethernet support team.
Thank you for your kind cooperation on this matter and stay safe.
Crisselle C.
CarlosAM_INTEL
Hello, @Daedalus:
You need to update your profile to the premier option to help you. You should fill out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/developer/premier-registration.html
You should use a business email address to evade any inconvenience. Please avoid the free email provider's address (such as the one provided by Hotmail, Gmail, Yahoo, or others).
@CarlosAM_INTEL.
