Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
I225 Power Supply
mmg
I have some questions regarding the intel I225-IT Ethernet Controller's power supply:
  • In the datasheet, it says w.r.t. +3.3V_PAD Pad-Voltage Domain Supply:
    Note: Short cutting this voltage domain with others of same nominal value is not allowed
    on the I225/I226. For optimal power-consumption figure of merits, the lowest
    possible voltage must be selected in the system.
    But in the reference schematic, the +3.3V_PAD pin is indeed connected with the other +3.3V pins. So is it ok to connect +3.3V_PAD to the other 3.3V pins as in reference the schematic?
  • How large is the maximum current draw of the I225-IT?
    I.e. what is the current, that the +3.3V_LAN supply must be able to deliver?
    The datasheet lists the maximum power at ~2W, but I suppose this is an average value, is it According to the PCIe spec, the PCIe 3.3V rail supplies up to 3A. Would this be sufficient to supply 4 I225's (i.e. a quad port NIC) ?
Thanks in advance for your help.
Marcel
CarlosAM_INTEL
Hello, @mmg:
We sent an email to the address associated with this account with information that may help you.
@CarlosAM_INTEL.
RKrug
Hi @CarlosAM_INTEL ,
can you send me also the information about the current etc., please?
Thank you!
BR,
Roland
CarlosAM_INTEL
Hello, @RKrug:
@CarlosAM_INTEL.
CarlosAM_INTEL
Hello, @RKrug:
Thanks for your reply via email.
We sent another email to the address associated with this account with information that may help you.
@CarlosAM_INTEL.
