Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
Regulator for i210-IT
NanjundaM
I'm using the I210-IT ethernet controller in my design.
I want to use the external supply for 1.5V and 0.9V.
(I'm planning to use switching regulator TPS62160QDSGRQ1 for 1.5V generation and TLV71209DBVT for the 0.9V generation.)
I wanted to know, is there any particular recommendations for the regulators ?
Is it good to use LDOs or switching regulators ?
How reliable is to use the internal regulators of I210-IT ?
Please help me with this.
Thanks & Regards,
Nanjunda M
CarlosAM_INTEL
Hello Nanju,
Thank you for contacting the Intel Embedded Community.
The information that may answer your questions is stated in section 12.7, on pages from 824 to 828 of the http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i210-ethernet-controller-datasheet.pdf Intel(R) Ethernet Controller I210 Datasheet.
We hope that this info is useful to you.
Carlos_A.
NanjundaM
Hi Carlos A,
I have been through those pages.
My question is
" is there any particular recommendations for the regulators ?
Is it good to use LDOs or switching regulators ? "
I don't see anything mentioned related to this in the datasheet.
Can you please help with this ?
Thanks & Regards,
Nanjunda M
CarlosAM_INTEL
Hello Nanju,
Thanks for your reply.
It is strongly recommended to use the internal regulator. The recommendations for external regulators are unavailable because that is not the preferred configuration.
The internal regulation is highly reliable, and there are hundreds of designs using it. In fact, the team in charge of this product don't recall ever seeing a design using an external regulator.
We hope that information may answer your questions.
Carlos_A.
