Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
957 Discussions
Uboot - e1000(Intel I210) driver fails to ping in Raspberry Pi Compute Module 4(Rpi CM4)
Rengarajan
Environment: Uboot v2025.07
Platform: Intel I210 connected to PCIe port of Raspberry Pi Compute Module 4(Rpi CM4).
Issue: I am trying to use e1000.c driver available at https://elixir.bootlin.com/u-boot/v2025.07/source/drivers/net/e1000.c  in Uboot v2025.07. I enabled E1000 = y, CONFIG_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCI_PNP=y CONFIG_ETH=y CONFIG_DM_ETH=y CONFIG_DM_ETH_PHY=y CONFIG_PHYLIB=y CONFIG_PHY_FIXED=y CONFIG_CMD_PCI=y CONFIG_CMD_NET=y in the make menuconfig. After flashing the image I could see e1000#0 enumerated properly.
However, during ping I am observing tx failure. In the transmit callback, we receive a packet, compute its physical address, and store it in a descriptor. The descriptor’s address is then flushed to RAM along with the packet so that the hardware can fetch it.
Post flushing the descriptor at that physical address, the PCIe controller attempts to read it and we get a PCIe Completer Abort in the PCIe trace. The error shows that PCIe is trying to access the physical address and fails after multiple retries.
Is there any configuration in the CM4’s U-Boot make menuconfig that needs to be enabled to ensure proper PCIe memory access or DMA mapping for e1000 driver in Uboot. Attached the i210 driver pcie trace taken during the start of ping.
IntelSupport
Community Manager
Hello Rengarajan,
Thank you for reaching out to Intel.
As your query is relates to programming or using a custom board with Intel® Ethernet chips (I210), we’ve moved your concern to the dedicated Embedded Connectivity forum:
https://community.intel.com/t5/Embedded-Connectivity/Uboot-e1000-Intel-I210-driver-fails-to-ping-in-Raspberry-Pi/m-p/1710484#M5840
Our dedicated team will assist you further from there.
Shankith K P
Diego_INTEL
Hello @Rengarajan,
Raspberry Pi is not an embedded product, you may try downloading the driver from this link:
https://sourceforge.net/projects/e1000/files/
You can try consulting with Raspberry Pi community regarding the compatibility with the i210.
@Diego_INTEL
Rengarajan
Hi @Diego_INTEL
Thanks for your reply. Can you please share the Uboot driver and release packages for e1000 driver.
Rengarajan S
Rengarajan
Hi Diego,
Can you please share the environment details in which the Uboot e1000 driver was tested so that we can use the same platform on our end.
Rengarajan S
