Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
WGI210IT S LJXT materials
suzanner
I'm looking for the base material of the pins on the WGI210IT S LJXT 64-pin QFN package. Can anyone tell me the leadframe material or give me a material declaration form for this package?
AlfredoS_Intel
Hi Suzanner,
Thank you for posting in our Intel® Ethernet Communities Page.
Since your issue is regarding an ethernet controller which is embedded , we need to route this thread to the correct group so you will be better assisted by the proper team.
Please wait for their reply within 1 to 2 business days.
Alfred S
Intel® Customer Support
CarlosAM_INTEL
Hello, @suzanner:
You can find the Material Data Declaration Sheet  (MDDS) of any Intel devices once you find them at the bottom of the ordering and specification information of the Intel Specifications portal on the following website:
https://ark.intel.com/
You can find the WGI210IT S LJXT MDDS on the following website:
http://qdms.intel.com/cn/XidyNFeotUKbY4bS9yahXg%3d%3d
@CarlosAM_INTEL.
suzanner
Thank you for your response. That MDDS appears to be for compliance purposes only and doesn't list the primary materials that make up the majority of the part.
Could you tell me the leadframe material?
Thanks-
CarlosAM_INTEL
Hello, @suzanner:
Thanks for your reply.
Based on your last communication, could you please let us know the reasons to request this information?
We are waiting for your clarification.
@CarlosAM_INTEL.
suzanner
Hi @AlfredoS_Intel
The information is to be used for thermal analysis purposes to determine heat transfer through the leads
Thank you
suzanner
Hi @CarlosAM_INTEL
Thank you
CarlosAM_INTEL
Hello, @suzanner:
Thanks for your update.
You can find the information that may help you in section 13, on pages 843 through 848 of the Intel® Ethernet Controller I210 Datasheet document # 333016, because heat dissipation is mostly done through the EPad on the bottom of the chip. and all of the thermal specs are stated in the cited section. You can find this datasheet on the following website:
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i210-ethernet-controller-datasheet.pdf
@CarlosAM_INTEL.
suzanner
Hi @CarlosAM_INTEL
Our thermal analysis method involves calculating all thermal resistances between the board and the junction to get as accurate of a number as possible, so we do not ignore resistance through the leads.
Please let me know what the leadframe material is.
Thank you
CarlosAM_INTEL
Hello, @suzanner:
We have contacted you via email using the address associated with your account of this community.
@CarlosAM_INTEL.
