Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
918 Discussions
Want to read/write to the I210 registers through the JTAG interface. Questions, what are some of JTAG debugger devices and what JTAG debugging software do you recommend for this task?
LLam0
Caguicla_Intel
Hello LLam0,
Thank you for posting in Intel Ethernet Communities. Your query will be best answered by our Embedded Support team, we will help you to move this post to the designated team. Please feel free to contact us if you need assistance from Ethernet support team.
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
CarlosAM_INTEL
Hello, @LLam0​:
Could you please tell us if the projects related to this forum have been designed by you or by a third-party company? In case that they are third-party units please give the part number, model, name of the manufacturer, where it is stated the information related to it. In case that it is your design, could you please clarify it has been reviewed by Intel and list the sources that you have used to develop it?
We are waiting for your answer.
@Mæcenas_INTEL​.
LLam0
Hi Maecenas,
This is our design, have not reviewed by Intel and we currently don't have any resource to develop it. I am simply looking for a JTAG debugger that I can plug into the I210 JTAG port and either through command line or some software that I can use to read the I210 registers.
CarlosAM_INTEL
Hello, @LLam0​:
Thanks for your reply.
The information that may help you is stated in sections 14.0 and 12.11, on pages 849, 850, 840, and 841 of the Intel(R) Ethernet Controller I210 Datasheet document # 333016 that can be found at:
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i210-ethernet-controller-datasheet.pdf
By the way, the tool that may help can be found when you are logged into your Resource & Design Center (RDC) privileged at:
https://designintools.intel.com/product_p/stlgrn34.htm
In case that you have questions related to this tool or if you need other, please address your questions to the email address listed at the previous website.
The RDC Account Support form is the channel to process your account update request or any inconvenience related to the provided website. It can be found at:
https://www.intel.com/content/www/us/en/forms/design/contact-support.html
@Mæcenas_INTEL​.
LLam0
Hi Maecenas,
Thank you for your response. Do the JTAG tools, from your link above and I am reposting it here for reference: https://designintools.intel.com/product_p/stlgrn34.htm
allow me to read and write (when writeable) to all the PCIe registers found in chapter 9 of the data sheet? (https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i210-ethernet-controller-datasheet.pdf)
If the JTAG tools allow only read/write (when writable) access to a subset of the PCIe registers then please list which subset or point me to a document that list this subset.
Thank you.
CarlosAM_INTEL
Hello, @LLam0​:
Thanks for your update.
In order to help you with your questions related to the suggested third-party tool, could you please confirm that you are following the suggestion provided next to the website related to this tool?
@Mæcenas_INTEL​.
