Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
899 Discussions
i210 internal PHY cannot auto-neg 1000Mbs
cgao
hello
I use i210 internal PHY in our  designed embeded system board,the internal PHY can  auto negotiate normally with 10Mbs/100Mbs Full/Half duplex. 1000Mbs full duplex cannot be auto negotiated whatever I set to auto-nego or 1G full-duplex forced at PC which connected to designed embeded system board by CAT 6,at the end it will show 100Mbs in PC network and share center.
I've tryed  iNVM , FLASH and manually config PHY without both of them as below:
/* PHY init IGP 3 */
    /* Enable rise/fall, 10-mode work in class-A */
    hw->phy.ops.write_reg(hw, 0x2F5B, 0x9018);
    /* Remove all caps from Replica path filter */
    hw->phy.ops.write_reg(hw, 0x2F52, 0x0000);
    /* Bias trimming for ADC, AFE and Driver (Default) */
    hw->phy.ops.write_reg(hw, 0x2FB1, 0x8B24);
    /* Increase Hybrid poly bias */
    hw->phy.ops.write_reg(hw, 0x2FB2, 0xF8F0);
    /* Add 4% to Tx amplitude in Gig mode */
    hw->phy.ops.write_reg(hw, 0x2010, 0x10B0);
    /* Disable trimming (TTT) */
    hw->phy.ops.write_reg(hw, 0x2011, 0x0000);
    /* Poly DC correction to 94.6% + 2% for all channels */
    hw->phy.ops.write_reg(hw, 0x20DD, 0x249A);
    /* ABS DC correction to 95.9% */
    hw->phy.ops.write_reg(hw, 0x20DE, 0x00D3);
    /* BG temp curve trim */
    hw->phy.ops.write_reg(hw, 0x28B4, 0x04CE);
    /* Increasing ADC OPAMP stage 1 currents to max */
    hw->phy.ops.write_reg(hw, 0x2F70, 0x29E4);
    /* Force 1000 ( required for enabling PHY regs configuration) */
    hw->phy.ops.write_reg(hw, 0x0000, 0x0140);
    /* Set upd_freq to 6 */
    hw->phy.ops.write_reg(hw, 0x1F30, 0x1606);
    /* Disable NPDFE */
    hw->phy.ops.write_reg(hw, 0x1F31, 0xB814);
    /* Disable adaptive fixed FFE (Default) */
    hw->phy.ops.write_reg(hw, 0x1F35, 0x002A);
    /* Enable FFE hysteresis */
    hw->phy.ops.write_reg(hw, 0x1F3E, 0x0067);
    /* Fixed FFE for short cable lengths */
    hw->phy.ops.write_reg(hw, 0x1F54, 0x0065);
    /* Fixed FFE for medium cable lengths */
    hw->phy.ops.write_reg(hw, 0x1F55, 0x002A);
    /* Fixed FFE for long cable lengths */
    hw->phy.ops.write_reg(hw, 0x1F56, 0x002A);
    /* Enable Adaptive Clip Threshold */
    hw->phy.ops.write_reg(hw, 0x1F72, 0x3FB0);
    /* AHT reset limit to 1 */
    hw->phy.ops.write_reg(hw, 0x1F76, 0xC0FF);
    /* Set AHT master delay to 127 msec */
    hw->phy.ops.write_reg(hw, 0x1F77, 0x1DEC);
    /* Set scan bits for AHT */
    hw->phy.ops.write_reg(hw, 0x1F78, 0xF9EF);
    /* Set AHT Preset bits */
    hw->phy.ops.write_reg(hw, 0x1F79, 0x0210);
    /* Change integ_factor of channel A to 3 */
    hw->phy.ops.write_reg(hw, 0x1895, 0x0003);
    /* Change prop_factor of channels BCD to 8 */
    hw->phy.ops.write_reg(hw, 0x1796, 0x0008);
    /* Change cg_icount + enable integbp for channels BCD */
    hw->phy.ops.write_reg(hw, 0x1798, 0xD008);
    /* Change cg_icount + enable integbp + change prop_factor_master
     * to 8 for channel A
    hw->phy.ops.write_reg(hw, 0x1898, 0xD918);
    /* Disable AHT in Slave mode on channel A */
    hw->phy.ops.write_reg(hw, 0x187A, 0x0800);
    /* Enable LPLU and disable AN to 1000 in non-D0a states,
     * Enable SPD+B2B
    hw->phy.ops.write_reg(hw, 0x0019, 0x008D);
    /* Enable restart AN on an1000_dis change */
    hw->phy.ops.write_reg(hw, 0x001B, 0x2080);
    /* Enable wh_fifo read clock in 10/100 modes */
    hw->phy.ops.write_reg(hw, 0x0014, 0x0045);
    /* Restart AN, Speed selection is 1000 */
    hw->phy.ops.write_reg(hw, 0x0000, 0x1340);
above config is  for PHY ID :0x02A80391 which i copyed from igb source code  ,actually  PHY ID is 0x01410C00  in PHY identify 1&2(Reg:2&3) cause I have no idea for this problem after trying throusand routes.
Does someone know what the issue could be?
Thanks a lot.
CarlosAM_INTEL
Hello, @cgao:
We sent an email to the address associated with this account with suggestions that may help you.
@CarlosAM_INTEL.
cgao
hello CarlosA,
I've tried new  case at IPS,but it looks like that step3-addproducts can be selected only support Intel CPU. could you give me some suggests if i use non-intel CPU system?
CarlosAM_INTEL
Hello, @cgao:
Thanks for your reply.
We suggest following the suggestions stated in the provided email to solve the mentioned inconvenience.
@CarlosAM_INTEL.
