Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
931 Discussions
[igb - Intel i210 NIC] eth1: Reset adapter .....igb 0000:01:00.0: Detected Tx Unit Hang
tzeng015
Hi all
I have a question about the I210 issue. Here is my information.
OS :Yocto and Linux version is 5.10.
Platform : NXP imx8mm.
Question :
(1) Issue linked
https://www.youtube.com/watch?v=wOhM4aDP9ws
(2) kernel messages
[ 2.580191] pci 0000:01:00.0: [8086:1533] type 00 class 0x020000
(3)
I try get network connection established. In dmesg I get repeatively messages regarding a TX hang and adapter reset:
[ 202.700164] igb 0000:01:00.0 enp1s0: igb: enp1s0 NIC Link is Up 1000 Mbps
(4)
Here is my log :
[ 15.076159] NETDEV WATCHDOG: eth1 (igb): transmit queue 0 timed out
[ 15.082512] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:485 dev_watchdog+0x300/0x310
[ 15.090781] Modules linked in: overlay fsl_jr_uio caam_jr caamkeyblob_desc caamhash_desc caamalg_desc crypto_engine rng_core authenc libdes crct10dif_ce caam secvio error gpio_ir_recv rc_core fuse
[ 15.108299] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.10.72-lts-5.10.y+g22ec7e8cbace #1
[ 15.116475] Hardware name: FSL i.MX8MM EVK board (DT)
[ 15.121529] pstate: 20000005 (nzCv daif -PAN -UAO -TCO BTYPE=--)
[ 15.127541] pc : dev_watchdog+0x300/0x310
[ 15.131552] lr : dev_watchdog+0x300/0x310
[ 15.135562] sp : ffff800011d4bd90
[ 15.138876] x29: ffff800011d4bd90 x28: ffff0000c1781940
[ 15.144193] x27: 0000000000000004 x26: ffff0000c177c480
[ 15.149511] x25: 0000000000000140 x24: 00000000ffffffff
[ 15.154829] x23: ffff0000c177c3dc x22: 0000000000000000
[ 15.160144] x21: ffff800011b36000 x20: ffff0000c177c000
[ 15.165460] x19: 0000000000000000 x18: 0000000000000030
[ 15.170775] x17: 0000000000000000 x16: 0000000000000000
[ 15.176091] x15: ffff800011b427f8 x14: ffffffffffffffff
[ 15.181406] x13: ffff800011b517b0 x12: 00000000000005dc
[ 15.186723] x11: 00000000000001f4 x10: ffff800011ba97b0
[ 15.192041] x9 : 00000000fffff000 x8 : ffff800011b517b0
[ 15.197359] x7 : ffff800011ba97b0 x6 : 0000000000000003
[ 15.202674] x5 : 0000000000000000 x4 : 0000000000000000
[ 15.207989] x3 : 0000000000000000 x2 : 0000000000000100
[ 15.213305] x1 : e2325e19108dc600 x0 : 0000000000000000
[ 15.218621] Call trace:
[ 15.221073] dev_watchdog+0x300/0x310
[ 15.224741] call_timer_fn.constprop.0+0x24/0x80
[ 15.229362] __run_timers.part.0+0x1f4/0x22c
[ 15.233633] run_timer_softirq+0x3c/0x7c
[ 15.237558] efi_header_end+0x124/0x290
[ 15.241396] irq_exit+0xdc/0xfc
[ 15.244541] __handle_domain_irq+0x80/0xe0
[ 15.248639] gic_handle_irq+0xc0/0x140
[ 15.252388] el1_irq+0xcc/0x180
[ 15.255534] cpuidle_enter_state+0x130/0x2f0
[ 15.259806] cpuidle_enter+0x38/0x50
[ 15.263385] do_idle+0x218/0x2a0
[ 15.266615] cpu_startup_entry+0x28/0x70
[ 15.270541] rest_init+0xd8/0xe8
[ 15.273774] arch_call_rest_init+0x10/0x1c
[ 15.277871] start_kernel+0x4ac/0x4e4
[ 15.281534] ---[ end trace d8df749d650a7ef8 ]---
a100 login:
a100 login: [ 15.286387] igb 0000:01:00.0 eth1: Reset adapter
root
root@a100:~# [ 18.268094] igb 0000:01:00.0 eth1: igb: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
[ 20.960737] igb 0000:01:00.0: Detected Tx Unit Hang
[ 20.960737] Tx Queue <0>
[ 20.960737] TDH <0>
[ 20.960737] TDT <1>
[ 20.960737] next_to_use <1>
[ 20.960737] next_to_clean <0>
[ 20.960737] buffer_info[next_to_clean]
[ 20.960737] time_stamp <fffeece7>
[ 20.960737] next_to_watch <00000000c7cd17aa>
[ 20.960737] jiffies <fffeef80>
[ 20.960737] desc.status <4f4000>
[ 21.005949] igb 0000:01:00.0: Detected Tx Unit Hang
[ 21.005949] Tx Queue <1>
[ 21.005949] TDH <0>
[ 21.005949] TDT <1>
[ 21.005949] next_to_use <1>
[ 21.005949] next_to_clean <0>
[ 21.005949] buffer_info[next_to_clean]
[ 21.005949] time_stamp <fffeece4>
[ 21.005949] next_to_watch <00000000058d6273>
[ 21.005949] jiffies <fffeef80>
[ 21.005949] desc.status <1b8000>
[ 21.051174] igb 0000:01:00.0: Detected Tx Unit Hang
[ 21.051174] Tx Queue <2>
[ 21.051174] TDH <0>
[ 21.051174] TDT <1>
[ 21.051174] next_to_use <1>
[ 21.051174] next_to_clean <0>
[ 21.051174] buffer_info[next_to_clean]
[ 21.051174] time_stamp <fffeedf1>
[ 21.051174] next_to_watch <00000000f8982935>
[ 21.051174] jiffies <fffeef97>
[ 21.051174] desc.status <118000>
[ 22.784344] igb 0000:01:00.0: Detected Tx Unit Hang
[ 22.784344] Tx Queue <0>
[ 22.784344] TDH <0>
[ 22.784344] TDT <1>
[ 22.784344] next_to_use <1>
[ 22.784344] next_to_clean <0>
[ 22.784344] buffer_info[next_to_clean]
[ 22.784344] time_stamp <fffeece7>
[ 22.784344] next_to_watch <00000000c7cd17aa>
[ 22.784344] jiffies <fffef148>
[ 22.784344] desc.status <4f4000>
[ 22.829554] igb 0000:01:00.0: Detected Tx Unit Hang
[ 22.829554] Tx Queue <1>
[ 22.829554] TDH <0>
[ 22.829554] TDT <1>
[ 22.829554] next_to_use <1>
[ 22.829554] next_to_clean <0>
[ 22.829554] buffer_info[next_to_clean]
[ 22.829554] time_stamp <fffeece4>
[ 22.829554] next_to_watch <00000000058d6273>
[ 22.829554] jiffies <fffef148>
[ 22.829554] desc.status <1b8000>
[ 22.874828] igb 0000:01:00.0: Detected Tx Unit Hang
[ 22.874828] Tx Queue <2>
[ 22.874828] TDH <0>
[ 22.874828] TDT <1>
[ 22.874828] next_to_use <1>
[ 22.874828] next_to_clean <0>
[ 22.874828] buffer_info[next_to_clean]
[ 22.874828] time_stamp <fffeedf1>
[ 22.874828] next_to_watch <00000000f8982935>
[ 22.874828] jiffies <fffef15e>
[ 22.874828] desc.status <118000>
[ 24.031849] igb 0000:01:00.0 eth1: Reset adapter
[ 27.032082] igb 0000:01:00.0 eth1: igb: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
[ 28.832147] igb 0000:01:00.0: Detected Tx Unit Hang
[ 28.832147] Tx Queue <0>
[ 28.832147] TDH <0>
[ 28.832147] TDT <1>
[ 28.832147] next_to_use <1>
[ 28.832147] next_to_clean <0>
[ 28.832147] buffer_info[next_to_clean]
[ 28.832147] time_stamp <fffef578>
[ 28.832147] next_to_watch <00000000c7cd17aa>
[ 28.832147] jiffies <fffef730>
[ 28.832147] desc.status <4f4000>
[ 28.877358] igb 0000:01:00.0: Detected Tx Unit Hang
[ 28.877358] Tx Queue <1>
[ 28.877358] TDH <0>
[ 28.877358] TDT <1>
[ 28.877358] next_to_use <1>
[ 28.877358] next_to_clean <0>
[ 28.877358] buffer_info[next_to_clean]
[ 28.877358] time_stamp <fffef573>
[ 28.877358] next_to_watch <00000000058d6273>
[ 28.877358] jiffies <fffef73b>
[ 28.877358] desc.status <1b8000>
[ 30.847744] igb 0000:01:00.0: Detected Tx Unit Hang
[ 30.847744] Tx Queue <0>
[ 30.847744] TDH <0>
[ 30.847744] TDT <1>
[ 30.847744] next_to_use <1>
[ 30.847744] next_to_clean <0>
[ 30.847744] buffer_info[next_to_clean]
[ 30.847744] time_stamp <fffef578>
[ 30.847744] next_to_watch <00000000c7cd17aa>
[ 30.847744] jiffies <fffef928>
[ 30.847744] desc.status <4f4000>
[ 30.893028] igb 0000:01:00.0: Detected Tx Unit Hang
[ 30.893028] Tx Queue <1>
[ 30.893028] TDH <0>
[ 30.893028] TDT <1>
[ 30.893028] next_to_use <1>
[ 30.893028] next_to_clean <0>
[ 30.893028] buffer_info[next_to_clean]
[ 30.893028] time_stamp <fffef573>
[ 30.893028] next_to_watch <00000000058d6273>
[ 30.893028] jiffies <fffef933>
[ 30.893028] desc.status <1b8000>
[ 30.938249] igb 0000:01:00.0: Detected Tx Unit Hang
[ 30.938249] Tx Queue <2>
[ 30.938249] TDH <0>
[ 30.938249] TDT <1>
[ 30.938249] next_to_use <1>
[ 30.938249] next_to_clean <0>
[ 30.938249] buffer_info[next_to_clean]
[ 30.938249] time_stamp <fffef6bb>
[ 30.938249] next_to_watch <00000000f8982935>
[ 30.938249] jiffies <fffef93e>
[ 30.938249] desc.status <118000>
[ 32.831747] igb 0000:01:00.0: Detected Tx Unit Hang
[ 32.831747] Tx Queue <0>
[ 32.831747] TDH <0>
[ 32.831747] TDT <1>
[ 32.831747] next_to_use <1>
[ 32.831747] next_to_clean <0>
[ 32.831747] buffer_info[next_to_clean]
[ 32.831747] time_stamp <fffef578>
[ 32.831747] next_to_watch <00000000c7cd17aa>
[ 32.831747] jiffies <fffefb18>
[ 32.831747] desc.status <4f4000>
[ 32.876970] igb 0000:01:00.0: Detected Tx Unit Hang
[ 32.876970] Tx Queue <1>
[ 32.876970] TDH <0>
[ 32.876970] TDT <1>
[ 32.876970] next_to_use <1>
[ 32.876970] next_to_clean <0>
[ 32.876970] buffer_info[next_to_clean]
[ 32.876970] time_stamp <fffef573>
[ 32.876970] next_to_watch <00000000058d6273>
[ 32.876970] jiffies <fffefb23>
[ 32.876970] desc.status <1b8000>
[ 32.922194] igb 0000:01:00.0: Detected Tx Unit Hang
[ 32.922194] Tx Queue <2>
[ 32.922194] TDH <0>
[ 32.922194] TDT <1>
[ 32.922194] next_to_use <1>
[ 32.922194] next_to_clean <0>
[ 32.922194] buffer_info[next_to_clean]
[ 32.922194] time_stamp <fffef6bb>
[ 32.922194] next_to_watch <00000000f8982935>
[ 32.922194] jiffies <fffefb2e>
[ 32.922194] desc.status <118000>
[ 33.759541] VSD_3V3: disabling
[ 34.847735] igb 0000:01:00.0: Detected Tx Unit Hang
[ 34.847735] Tx Queue <0>
[ 34.847735] TDH <0>
[ 34.847735] TDT <1>
[ 34.847735] next_to_use <1>
[ 34.847735] next_to_clean <0>
[ 34.847735] buffer_info[next_to_clean]
[ 34.847735] time_stamp <fffef578>
[ 34.847735] next_to_watch <00000000c7cd17aa>
[ 34.847735] jiffies <fffefd10>
[ 34.847735] desc.status <4f4000>
[ 34.893044] igb 0000:01:00.0: Detected Tx Unit Hang
[ 34.893044] Tx Queue <1>
[ 34.893044] TDH <0>
[ 34.893044] TDT <1>
[ 34.893044] next_to_use <1>
[ 34.893044] next_to_clean <0>
[ 34.893044] buffer_info[next_to_clean]
[ 34.893044] time_stamp <fffef573>
[ 34.893044] next_to_watch <00000000058d6273>
[ 34.893044] jiffies <fffefd1b>
[ 34.893044] desc.status <1b8000>
[ 34.938272] igb 0000:01:00.0: Detected Tx Unit Hang
[ 34.938272] Tx Queue <2>
[ 34.938272] TDH <0>
[ 34.938272] TDT <1>
[ 34.938272] next_to_use <1>
[ 34.938272] next_to_clean <0>
[ 34.938272] buffer_info[next_to_clean]
[ 34.938272] time_stamp <fffef6bb>
[ 34.938272] next_to_watch <00000000f8982935>
[ 34.938272] jiffies <fffefd26>
[ 34.938272] desc.status <118000>
[ 36.831565] igb 0000:01:00.0 eth1: Reset adapter
[ 36.836243] igb 0000:01:00.0 eth1: igb: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
[ 36.973032] igb 0000:01:00.0 eth1: igb: eth1 NIC Link is Down
[ 37.823691] igb 0000:01:00.0 eth1: Reset adapter
[ 39.839717] igb 0000:01:00.0 eth1: Reset adapter
[ 42.784090] igb 0000:01:00.0 eth1: igb: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
[ 45.024153] igb 0000:01:00.0: Detected Tx Unit Hang
[ 45.024153] Tx Queue <0>
[ 45.024153] TDH <0>
[ 45.024153] TDT <1>
[ 45.024153] next_to_use <1>
[ 45.024153] next_to_clean <0>
[ 45.024153] buffer_info[next_to_clean]
[ 45.024153] time_stamp <ffff04d8>
[ 45.024153] next_to_watch <00000000c7cd17aa>
[ 45.024153] jiffies <ffff0700>
[ 45.024153] desc.status <4f4000>
[ 45.069369] igb 0000:01:00.0: Detected Tx Unit Hang
[ 45.069369] Tx Queue <1>
[ 45.069369] TDH <0>
[ 45.069369] TDT <1>
[ 45.069369] next_to_use <1>
[ 45.069369] next_to_clean <0>
[ 45.069369] buffer_info[next_to_clean]
[ 45.069369] time_stamp <ffff04d5>
[ 45.069369] next_to_watch <00000000058d6273>
[ 45.069369] jiffies <ffff070b>
[ 45.069369] desc.status <1b8000>
[ 45.114595] igb 0000:01:00.0: Detected Tx Unit Hang
[ 45.114595] Tx Queue <2>
[ 45.114595] TDH <0>
[ 45.114595] TDT <1>
[ 45.114595] next_to_use <1>
[ 45.114595] next_to_clean <0>
[ 45.114595] buffer_info[next_to_clean]
[ 45.114595] time_stamp <ffff0561>
[ 45.114595] next_to_watch <00000000f8982935>
[ 45.114595] jiffies <ffff0716>
[ 45.114595] desc.status <118000>
[ 47.839743] igb 0000:01:00.0 eth1: Reset adapter
[ 50.780084] igb 0000:01:00.0 eth1: igb: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
[ 52.960435] igb 0000:01:00.0: Detected Tx Unit Hang
[ 52.960435] Tx Queue <0>
[ 52.960435] TDH <0>
[ 52.960435] TDT <1>
[ 52.960435] next_to_use <1>
[ 52.960435] next_to_clean <0>
[ 52.960435] buffer_info[next_to_clean]
[ 52.960435] time_stamp <ffff0ca7>
[ 52.960435] next_to_watch <00000000c7cd17aa>
[ 52.960435] jiffies <ffff0ec0>
[ 52.960435] desc.status <4f4000>
[ 53.005654] igb 0000:01:00.0: Detected Tx Unit Hang
[ 53.005654] Tx Queue <1>
[ 53.005654] TDH <0>
[ 53.005654] TDT <1>
[ 53.005654] next_to_use <1>
[ 53.005654] next_to_clean <0>
[ 53.005654] buffer_info[next_to_clean]
[ 53.005654] time_stamp <ffff0ca4>
[ 53.005654] next_to_watch <00000000058d6273>
[ 53.005654] jiffies <ffff0ecb>
[ 53.005654] desc.status <1b8000>
[ 53.050903] igb 0000:01:00.0: Detected Tx Unit Hang
[ 53.050903] Tx Queue <2>
[ 53.050903] TDH <0>
[ 53.050903] TDT <1>
[ 53.050903] next_to_use <1>
[ 53.050903] next_to_clean <0>
[ 53.050903] buffer_info[next_to_clean]
[ 53.050903] time_stamp <ffff0d31>
[ 53.050903] next_to_watch <00000000f8982935>
[ 53.050903] jiffies <ffff0ed6>
[ 53.050903] desc.status <118000>
[ 54.847755] igb 0000:01:00.0: Detected Tx Unit Hang
[ 54.847755] Tx Queue <0>
[ 54.847755] TDH <0>
[ 54.847755] TDT <1>
[ 54.847755] next_to_use <1>
[ 54.847755] next_to_clean <0>
[ 54.847755] buffer_info[next_to_clean]
[ 54.847755] time_stamp <ffff0ca7>
[ 54.847755] next_to_watch <00000000c7cd17aa>
[ 54.847755] jiffies <ffff1098>
[ 54.847755] desc.status <4f4000>
[ 54.892978] igb 0000:01:00.0: Detected Tx Unit Hang
[ 54.892978] Tx Queue <1>
[ 54.892978] TDH <0>
[ 54.892978] TDT <1>
[ 54.892978] next_to_use <1>
[ 54.892978] next_to_clean <0>
[ 54.892978] buffer_info[next_to_clean]
[ 54.892978] time_stamp <ffff0ca4>
[ 54.892978] next_to_watch <00000000058d6273>
[ 54.892978] jiffies <ffff10a3>
[ 54.892978] desc.status <1b8000>
[ 54.938192] igb 0000:01:00.0: Detected Tx Unit Hang
[ 54.938192] Tx Queue <2>
[ 54.938192] TDH <0>
[ 54.938192] TDT <1>
[ 54.938192] next_to_use <1>
[ 54.938192] next_to_clean <0>
[ 54.938192] buffer_info[next_to_clean]
[ 54.938192] time_stamp <ffff0d31>
[ 54.938192] next_to_watch <00000000f8982935>
[ 54.938192] jiffies <ffff10ae>
[ 54.938192] desc.status <118000>
Please kindly help me .
thank you
tzeng015
tzeng015
Hi Supports
This is my question.
(34) I210 bug report - YouTube
thank you
tzeng015
tzeng015
Hi
Does any body know the dst of linux arrang ?
Our platform imx8mm and the os is Youto Linux 5.10. I just reference the attach file in the linux .
Any other reference ?
thank you
tzeng015
tzeng015
Hi all
I don't know how to control the two pins which are " PE_RST" and "PE_WAKE". According the video , I210 can't receive the data so I think this is the key point.
Can you give a hand ?
Jaime_Lizarme
Hello Jeffrey,
We sent an email to the address associated with this account with information that may help you.
Jaime L.
tzeng015
The problem is still there. Anyone can help me ?
thank you
tzeng015
tzeng015
