环境:windows10 21h1 x64,处理器:intel(R) Atom(TM) Processor E3930
1、在未安装显卡驱动,也就是使用操作系统自带的显卡驱动时图像显示输出正常
2、在官网下载、安装intel提供的显卡驱动后,检测到输出的图像出现问题(如通过画图工具绘制RGB为‘0,128,0’的图像并全屏显示,检测到实际输出的rgb值不为'0,128,0'),显示图像与输入的图像灰度值不匹配,且最大值只能达到252,不能达到255
3、尝试通过显卡控制面板关闭对显示器的颜色增强处理,没有找到能关闭提供关闭处理的配置项。
请问:我该如何解决这种因为安装驱动后导致的显示失真问题?
chinanier, Thank you for posting in the Intel® Communities Support.
Just to let you know, we only provide support in English language and currently, we are using a translation tool.
In order for us to be able to provide the most accurate assistance o this topic, I just moved your thread to the proper department, they will further assist you with this scenario as soon as possible.
Albert R.
Hello, @chinanier:
We want to address the following questions to understand this situation:
Could you please tell us if the affected units are third-party designs or have been developed by you? In case that they are third-party devices, could you please give us all the information related to them?
Could you please let us if the mentioned graphic card is an add-in third-party device or designed by you? Could you please give the name of the manufacturer, model, and where is stated the information related to it?
We are waiting for your answer.
