1239 Discussions
Bay trail Atom E3845 100MHz clock run time
frankhh
Hi All,
I got a PCIE device initial problem.
I would like to early output the 100Mhz clock or delay the platform reset signal.
Would the TXE  change the timing?
Thanks in Advance.
CarlosAM_INTEL
Hello, @frankhh:
You need to confirm the workarounds of the errata VLI58 and VLI60 are implemented in the affected designs. You need to review this information on pages 33 and 34 of the Intel Atom(R) Processor E3800 Specification Update document # 329901. You need to be logged into your Resource & Design Center (RDC) privileged account to find the specification update on the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/329901.htm
The RDC Account Support form is the channel to process your update account or report any problems with the provided site. You should fill it out on the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
