I am trying to follow the instructions from https://www.intel.com/content/dam/develop/external/us/en/text/intelatome3900-0-71-buildinstructions.txt
It references
IntelAtomE3900-0.71-Binary.Objects.zip
from https://firmware.intel.com/projects/IntelAtomProcessorE3900 . Currently that file download, and basically every other link on that page are all broken. Please ask the web administrators to correct the URLs, because without that it's not possible to build the code from source (or to download the pre-build firmware.)
The instructions also reference
Intel21.1\APPS\EFI\EFIx64\E7320X3.EFI
from https://downloadcenter.intel.com/download/19186/Intel-Ethernet-Connections-Boot-Utility-Preboot-Images-and-EFI-Drivers. However, version 21.1 is no longer available, and E7320X3.EFI doesn't exist in newer versions.
The instructions also reference http://www.asix.com.tw/FrootAttach/driver/AX88179_178A_UEFI_V2.8.0.zip which is a broken link now as well.
Hello 090,
We will move your question to the correct subforum, and the team in charge will get back to you soon.
Jean O.
Hi @090 ,
Just a note to let you know that We re going to inform about your findings internally. Thanks for letting us know.
Jaime L.
I'm also finding these files for UEFI development learning with UP Squared board. Please contact me if anyone can share these files with me.
zhihua huang
Hello, @huangzh:
Your questions related to the cited third-party board series should be addressed as a reference to the channels listed on the following websites:
https://up-board.org/upsquared/specifications/#Community
