1069 Discussions
Broken links for Atom E3900 series UEFI binaries
090
I am trying to follow the instructions from https://www.intel.com/content/dam/develop/external/us/en/text/intelatome3900-0-71-buildinstructions.txt
It references
IntelAtomE3900-0.71-Binary.Objects.zip
from https://firmware.intel.com/projects/IntelAtomProcessorE3900 . Currently that file download, and basically every other link on that page are all broken. Please ask the web administrators to correct the URLs, because without that it's not possible to build the code from source (or to download the pre-build firmware.)
The instructions also reference
Intel21.1\APPS\EFI\EFIx64\E7320X3.EFI
from https://downloadcenter.intel.com/download/19186/Intel-Ethernet-Connections-Boot-Utility-Preboot-Images-and-EFI-Drivers. However, version 21.1 is no longer available, and E7320X3.EFI doesn't exist in newer versions.
The instructions also reference http://www.asix.com.tw/FrootAttach/driver/AX88179_178A_UEFI_V2.8.0.zip which is a broken link now as well.
CarlosAM_INTEL
Hello, @090:
You should address your request as a reference through the channel stated on the following website:
https://github.com/tianocore/edk2-platforms/pulls
@CarlosAM_INTEL.
