Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
1230 Discussions
Chipset INF Utility for Atom C2358
lianxu
Our servers use Intel Atom CPU C2358 and Windows Server 2012 R2. Current Chipset INF Utility version is 10.0.26.
As per the vulnerability recommendation, we should update the version to 10.1.18 or later.
So, I downloaded the software from Download Chipset INF Utility (intel.com). But it cannot be installed on the server with a failure "This platform is not supported".
I found another one from Download Intel® Chipset C240 Series Driver for Server Systems based on the Intel® Server Board M10JNP2SB, but after installation the version is 10.1.17968.8131 which still has the vulnerability.
Where can I download the correct version that is compatible with our server?
Alberto_Sykes
lianxu, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, just to let you know, we have a forum for those specific issues and I am moving your thread there so you can get the information that you are looking for as soon as possible.
Albert R.
CarlosAM_INTEL
Hello, @lianxu:
You should use the Intel® Driver & Support Assistant (Intel® DSA) that automatically detects and let you know the proper update of the chipset INF file and will prompt you to install it. You can find this tool on the following website:
https://www.intel.com/content/www/us/en/support/detect.html
@CarlosAM_INTEL.
lianxu
@CarlosAM_INTEL Thank you for your answer.  But the browser is disabled in the server, and I cannot even open the Intel® Driver & Support Assistant. Is there other way to get the proper update?
CarlosAM_INTEL
Hello, @lianxu:
Thanks for your reply.
We want to address the following questions to understand the reported situation:
Could you please let us know the versions, names, and the procedure followed to obtain the drivers used previously that worked properly?
Could you please let us know if the affected device is your own design or it is a third-party one?
We are waiting for your answers to these questions.
@CarlosAM_INTEL.
