Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
1154 Discussions
¿Cuál es el Sistema Operativo recomendado en 2021 para un Atom N2600 4Gb de RAM?
jgmeerino
Hola,
Tengo un Toshiba N510 con procesador Atom N2600 64bits con la RAM actualizada a 4Gb y con una disco SSD 512Gb.
¿Cuál sería el Sistema Operativo recomendado para mi equipo y que permite actualizaciones?
CarlosAM_INTEL
Hello, @jgmeerino:
We provide support only in the English language.
You need to confirm the information provided in this channel with the manufacturer of the third-party device because it is generic.
You can find the list of the validated Operating Systems for the mentioned processor on page 3 of the  Intel® Atom™ Processor N2000 and D2000 Series with Intel® NM10 Express Chipset Embedded Computing Platform brief document # 600325. This document can be found when you are logged into your Resource and Design Center (RDC) privileged account on the following website:
https://cdrdv2.intel.com/v1/dl/getContent/600325
You should fill out the form stated on the following website when you have problems with the provided website or want to update your RDC account:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
You can find a tool that can help to find the generic drivers of the mentioned processor on the following website:
https://www.intel.com/content/www/us/en/support/detect.html
@CarlosAM_INTEL
jgmeerino
Muchas gracias Carlos pero tu respuesta no me ha sido de gran ayuda.
Lo que necesito es instalar un Sistema Operativo con actualizaciones y que funcione de manera fluida con un procesador ATOM N2600 en 2021
CarlosAM_INTEL
Hello, @jgmeerino:
Thanks for your reply.
We should suggest again contact the manufacturer of the cited device to receive the proper information.
@CarlosAM_INTEL.
