Hola,
Tengo un Toshiba N510 con procesador Atom N2600 64bits con la RAM actualizada a 4Gb y con una disco SSD 512Gb.
¿Cuál sería el Sistema Operativo recomendado para mi equipo y que permite actualizaciones?
Hello, @jgmeerino:
We provide support only in the English language.
You need to confirm the information provided in this channel with the manufacturer of the third-party device because it is generic.
You can find the list of the validated Operating Systems for the mentioned processor on page 3 of the Intel® Atom™ Processor N2000 and D2000 Series with Intel® NM10 Express Chipset Embedded Computing Platform brief document # 600325. This document can be found when you are logged into your Resource and Design Center (RDC) privileged account on the following website:
https://cdrdv2.intel.com/v1/dl/getContent/600325
You should fill out the form stated on the following website when you have problems with the provided website or want to update your RDC account:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
You can find a tool that can help to find the generic drivers of the mentioned processor on the following website:
https://www.intel.com/content/www/us/en/support/detect.html
Lo que necesito es instalar un Sistema Operativo con actualizaciones y que funcione de manera fluida con un procesador ATOM N2600 en 2021
Hello, @jgmeerino:
Thanks for your reply.
We should suggest again contact the manufacturer of the cited device to receive the proper information.
