1266 Discussions
Questions concerning E3845 ATOM CPU. Boot problems caused by system stuck in S5# hibernation status
pirob110
Hello.
We have a product featuring an E3845 (1.91Ghz, 2M cache ) intel ATOM CPU. It is mounted on a SOM module designed by an OEM (part number 047310 from Congatec TCA3 serie) . We have received multiple systems from clients that are not functionnal.
What I mean by ‘not functional’ is that the CPU stays stuck in S5 hibernation status. This behaviour remains even after a power cycle occurs. It seems to be a static phenomena.
Our OEM confirmed that the SOM units could not be repaired, because die changes goes beyond their standard repair process. Die out , chip out & scratches could be observed on every die exhibiting these symptoms. We have multiple questions for you :
- While reading this document ( 600834-329901-intel-atom-processor-e3800-product-family-su-rev015_ERRATA.pdf ) . We’ve stumble on errata VLI89. We think it could apply to us, since the pull up resistor voltage is 3.3V ( and not 1.8V ). Could you give us more insights on this errata ? How should we handle it ? Could it explain why these  units stop booting after 3-4 years of continuous operation in the field ? The Errata says that 'under certain conditions where activity is high for several years'. What would be the exact conditions ? What would represent high activity and how much years does several years means ?
- What would be the maximal pressure that must not be exceeded on the die ( FCBGA e3845 ATOM CPU ) when applying the paste & screwing the heatsink on ?
- Could it be possible for Intel to review our mechanical heat dissipation architecture ? If so , how shall we proceed ( on the NDA side of things ) ?
- Finally, it has come to our attention that the paste has a sandpaper ( abrasive) effect on the die when we clean it. The cleaning process generate scratches ( they still are less intense than the original scratches ). Could a tape or a PCM be a better alternative ?Could the thermal paste generate scratches with vibration during transport for instance ( the sink squeezes the abrasive paste on the die ) ? The paste part number is SARCON SPG-50A.
Thank you very much for your great insights. Have a great day.
Jaime_Lizarme
Hi Pierre,
Please check your registered email, as I sent you some feedback about your CPU question.
Jaime L.
pirob110
Hi Jaime.
The Bay Trail processor serie does not seems to be a supported product by the IPS anymore ( I can't find it anywhere in the list of available products ). Is talking directly to the OEM the only possibility in my case ?
Thank you. Have a great day.
Jaime_Lizarme
Hi Pierre,
I have double checked and you are right, Baytrail CPU supports is discontinued by Intel, so then yes please refer your questions to the OEM.
Jaime L.
