1098 Discussions
Recommended Solder Paste for Intel Atom E3845
Sam2021US
Does anymore know what are the recommend Solder Paste for Intel Atom E3845 embedded processor?
Sam
CarlosAM_INTEL
Hello, @Sam2021US:
The information stated in section 9-2, on page 2 of the following document may answer your question:
https://www.intel.com/content/dam/www/public/us/en/documents/packaging-databooks/packaging-chapter-09-databook.pdf
The cited device is a lead-free device (RoHS compliant) as you may confirm on the following websites:
https://qdms.intel.com/MDDS/MDDSView.aspx?mm=962762
https://qdms.intel.com/MDDS/MDDSView.aspx?mm=932052
https://qdms.intel.com/MDDS/MDDSView.aspx?mm=935332
@CarlosAM_INTEL.
Sam2021US
Thank You @CarlosAM_INTEL.
Is it possible for you to tell me if this solder paste type below fits requirement for soldering the E3845 Atom processor?
"KOKI no-clean LEAD-FREE solder paste, model S3X58-M406-3"
https://www.ko-ki.co.jp/en/products/detail/9/
http://enterkom.by/f/technical-information-s3x58-m406-3.pdf
Sam
CarlosAM_INTEL
Hello, @Sam2021US:
Thanks for your reply.
You need to confirm with the manufacturer of the cited product that it fulfills the requirements provided in the Intel documentation.
@CarlosAM_INTEL.
Sam2021US
Hi @CarlosAM_INTEL,
Thank you very much for pointing me in right direction.
That was very helpful.
-Sam
CarlosAM_INTEL
Hello, @Sam2021US:
We are glad that the provided information helps you.
Please do not hesitate to contact us again if you have any questions related to Intel Embedded devices.
@CarlosAM_INTEL.
