Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1358 Discussions
82580 Transceiver 4 ports set to different types of interfaces
RDiva
I'd like to set port 1 on my 82580 in 1000base-BX mode and the remaining 3 ports in SGMII mode. In my current hardware, I have wired the LAN0 MDC/MDIO lines to the PHYs. LAN0 is a 1000 base BX connection to a back plane. If I use Intel's pre-configured EEPROM files and manipulate them I am unable to get the configuration I want to work. Right now I have a test set up with the dual version of the 82580 and if I set both ports to 1000 base BX or both to SGMII then they work in two test set ups I have. I am unable to get it to work if I set one to 1000 base BX and the other to SGMII.
My final configuration will use a quad where first port is 1000base-BX and the remaining three SGMII.
Is there an EEPROM build with first port set to 1000base-BX and the remaining three in SGMII. I also need the MDC/MDIO access from LAN0 port to access the 3 PHYs.
CarlosAM_INTEL
Hello, divram:
Based on your previous communication, could you please clarify if the affected project has been manufactured by you or by a third-party company? In case that it is a third-party device, could you please give us the part number, model, and where to find its documentation?
Thanks in advance for your cooperation.
Carlos_A.
RDiva
Hello Carlos,
I work for Cornet Technology, Inc. and the hardware was designed and Manufactured by my company.
CarlosAM_INTEL
Hello, divram:
Thanks for your reply.
We will contact you via email.
Carlos_A.
RDiva
Thanks a lot,
that will be of great help to us.
