Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1380 Discussions
Display driver igfxn stopped responding and has successfully recovered
THarr1
We have a motherboard that we designed with TigerLake i7-11850HE CPU. The OS is Windows 10 IoT LTSC 2021. We run Passmark BurninTest 10.2 to exercise the system. When running Passmark 3D test we get an error and the aligns with an error in Event Viewer "Display driver igfxn stopped responding and has successfully recovered". The Intel driver is 31.0.101.4641 8/1/23. This happens MOST of the time on all systems anywhere from 0 to 5 times. We test we need to resolve it. What can we do to prevent this from happening so Passmark will complete the 12 hr test with a PASSED status?
NormanS_Intel
Hello THarr1,
Thank you for posting in the community!
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Embedded Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Norman S.
Diego_INTEL
Hello @THarr1,
I looked internally and there is one solution that has been shared that may help with this issue:
"Search for the registry key in registry editor: DisplaySoftwareWaControl and set the value to 1".
Also, I have seen in other platforms that Passmark BurninTest version may affect, as with an older version the issue was present but with a version update it got fixed. If you still have the problem, it could be fixed on their side too with a newer version in the future.
@Diego_INTEL
