- Email to a Friend
We started getting intermittent failures recently using EEUPDATEW32 5.30.22.00 (as discussed on the Community forums here: https://communities.intel.com/thread/122076 https://communities.intel.com/thread/122076)
To try to address the intermittent failures, I tried the latest version of EEUPDATEW32.exe (in 348742-348742-quartzville-tools-488559.zip - "Intel Network Connections Tools 23.0 PV LAN Software Tools, 02-Feb-2018), and encountered a surprising new problem:
The new Windows 32-bit version (EEUPDATEW32.exe - version 5.30.25.6) does not seem to work at all in any version of 32-bit Windows, including:
- Windows PE 10 x86
- Windows 7 SP1 x86
- Windows 10 Enterprise 2016 LTSB x86
For example, in Windows 10, after running the provided "install.bat", the command: EEUPDATEW32 /mac_dump_all
results in an application error in the Windows Event Log:
Faulting application name: EEUPDATEW32.exe, version: 5.30.25.6, time stamp: 0x5a3a85d3
Faulting module name: EEUPDATEW32.exe, version: 5.30.25.6, time stamp: 0x5a3a85d3
Exception code: 0xc0000409
Fault offset: 0x00237963
Faulting process id: 0x1640
Faulting application start time: 0x01d3edeb39002b35
Faulting application path: C:\temp\EEUPDATEW32.exe
Faulting module path: C:\temp\EEUPDATEW32.exe
Report Id: 493385e5-da86-4209-9bf3-77a3f74d4e2e
Faulting package full name:
Faulting package-relative application ID:
Is this a known problem?
- Email to a Friend
Hello, h241x :
In order to help you, we will contact you via email.
Carlos_A.
