Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
EEUpdate /verify seems unreliable
MSchl5
We are trying to find a way to verify that eeupdate has actually updated the i210 NIC fw after it says it succeeded.
As part of my investigating, I have attempted to use /verify immediately after flashing the fw, as well as after power cycling the unit (20+ seconds). eeupdate /verify pretty much always reports an error of some sort.
I have done pretty much the same thing in WinPE10 32-bit, WinPE10 64-bit, and EFI-shell with different versions of the tools, with basically the same results.
X:\Temp\i210-FwUpdate>EEUPDATEW32.exe /nic=2 /d I210_Ver.3.25_20171012.bin
Using: Intel (R) PRO Network Connections SDK v2.32.12
EEUPDATE v5.32.12.00
Copyright (C) 1995 - 2018 Intel Corporation
Intel (R) Confidential and not for general distribution.
NIC Bus Dev Fun Vendor-Device Branding string
1 5 00 00 8086-1533 Intel(R) I210 Gigabit Network Connection
2 6 00 00 8086-1533 Intel(R) I210 Gigabit Network Connection
3 7 00 00 8086-1533 Intel(R) I210 Gigabit Network Connection
4 16 00 00 8086-1533 Intel(R) I210 Gigabit Network Connection
Writing SHARED FLASH. PLEASE DO NOT INTERRUPT THIS PROCESS.
2: Shared Flash image updated successfully.
X:\Temp\i210-FwUpdate>EEUPDATEW32.exe /all /verify I210_Ver.3.25_20171012.bin
1%1: Image Verification Test Failed - Flash verify error at offset 0x4
1%2: Image Verification Test Failed - Flash verify error at offset 0x4
3: Image Verification Test Failed - Flash read error at offset 0x64
1%4: Image Verification Test Failed - Flash verify error at offset 0x0
Am I doing something wrong? Do I have an incorrect understanding of how /verify should work?
Are there different tools for different x86-64 CPUs such as Core i5 vs. ApolloLake vs. Kaby lake? I'm assuming the same tools work across these CPUs.
CarlosAM_INTEL
Hello, ftms:
Based on your previous communication, could you please clarify if the affected project has been manufactured by you or by a third-party company? In case that it is a third-party device, could you please give us the part number, model, and where to find its documentation?
Thanks in advance for your cooperation.
Carlos_A.
MSchl5
The i210 NICs are in a MB manufactured for us by our vendor.
CarlosAM_INTEL
Hello, ftms:
Thanks for your clarification.
Based on your communications, could you please verify that your implementation fulfills with the requirements stated in the answers to the questions 2.14, 2.15, 2.16, and 2.23; on pages 8 and 9 of the https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf Intel(R) Ethernet Controller I210/I211 Frequently Asked Questions [FAQs] document # 335346?
Could you let us know the sources that you have used to implement the affected design? By the way, could you please tell us if it has been reviewed by Intel?
Waiting for your reply to these questions.
Carlos_A.
