Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
FH8065301487717 SR3UT
SHark
I need to purchase FH8065301487717 SR3UT, but I only see stock available for FH8065301487717 SR1X6
The following web site lists the different versions
https://ark.intel.com/products/78475/Intel-Atom-Processor-E3845-2M-Cache-1_91-GHz
My question is:
What is the difference between the SR3UT and SR1X6 versions.
Can I use FH8065301487717 SR1X6 in place of FH8065301487717 SR3UT?
The CPU will be soldered onto one of our custom designed Xerox circuit boards.
I was directed to this forum by Intel when after a raised Service request https://supporttickets.intel.com/requestdetail?id=5000P00000k3Q7XQAU&lang=en-US 03656171
Thanks in advance
Shaun
CarlosAM_INTEL
Hello, Xerox_Dundalk:
You are welcome.
Please keep in mind the following information in case that you want to use the D0 instead of the D1:
This information is stated on page 41 of the https://www.intel.com/content/dam/www/public/us/en/documents/specification-updates/atom-e3800-family-spec-update.pdf Intel Atom(R) Processor E3800 (Formerly Bay Trail -I SoC) Specification Update document # 329901.
We hope that this information may help you.
Carlos_A.
CarlosAM_INTEL
Hello, Xerox_Dundalk :
The difference between these devices is the steeping and are compatible. This information can be confirmed in the ordering and spec information section of the website that you have provided as you may notice in the yellow-highlighted information at the following screenshot:
Carlos_A .
SHark
Thankyou for the information Carlos A,
Typically, when an integrated circuit manufacturer such as Intel or AMD invests money to do a stepping (i.e. a revision to the masks), they have found bugs in the logic, have made improvements to the design that allow for faster processing, have found a way to increase yield or improve the "bin splits" (i.e., create faster transistors and hence faster CPUs), improve maneuverability to more easily identify marginal circuits, or reduce test time which can reduce the cost of testing the part.
In this case the stepping of the two parts are:
  • FH8065301487717 SR1X6 D0
  • FH8065301487717 SR3UT D1
I would like to use D0 in place of D1, it turns out there is a change (VLI89)
CarlosAM_INTEL
You are welcome.
Carlos_A.
