Hello
Currently, we are developing a solution related to encryption/decryption acceleration with the C627 Chipset. I had a problem during the development process and I wrote.
Currently, the installed driver file of C627 Chipset is using qat1.7.l.4.10.0-00014.tar.
For the general sample source test provided by Intel, the test was completed by referring to the document provided by Intel.
Test Source Path : /QAT/quickassist/lookaside/access_layer/src/sample_code/functional
Reference documents :
1. Intel QuickAssist Technology API Programmer's Guide
2. Intel QuickAssist Technology Cryptographic API Reference
However, when a sample source containing FIPS-related modules is compiled, fips_sample.a and fips_sample_s.so are generated, not TEST executable files, unlike other sample sources.
Test Source Path : /QAT/quickassist/lookaside/access_layer/src/sample_code/fips
The sample source provided in the aforementioned INTEL document can be applied to the solution we are developing through examples and TEST executable files. However, FIPS-related test sample sources are having difficulty due to lack of examples and documents.
Is there a place to get examples(/QAT/quickassist/lookaside/access_layer/src/sample_code/fips) and documentation related to the sample source in that path?
We are looking forward to your response.
Thank you.
Hello, @rekcah:
You should address as a reference your QAT consultations to the channels listed in the following website:
