Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
I350 register read/write
CHuan73
初学者
1,663 次查看
I'm developing the diagnostic application on a embedded system which using the Broadwell DE processor and I350 Ethernet Controller.
There're two purposes as following but not sure whether these are doable in "user-space application" or not:
 P1. Read/Write Register on I350.
 P2. Performing loopback test on I350 in specific speed(10/100/1000Mbps) without Celo.
If P1 is doable, should I use iqvlinux or igb driver to access I350 register in user-space(i.e., create a file descriptor then access driver via ioctl).
Chih-Yuan Huang
0 项奖励
1 回复
CarlosAM_INTEL
主持人
1,041 次查看
​Hello, @CHuan73​:
In order to be on the same page, could you please clarify if the application that you want to develop is similar to the one stated as a reference at the following website?
http://rweverything.com/
Waiting for the answer to our question.
@Mæcenas_INTEL​.
0 项奖励
回复
