Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
MTBF of i3-6100TE & i5-6500TE
jzhao54
Could you share me the MTBF of i3-6100TE & i5-6500TE?
It will be more appreciative if you can tell me the relationship between MTBF and case/ambient temperature.
Thanks in advance.
Junjie
Leonardo_C_Intel
Hello jzhao54 Thank you for posting in the Intel Community. I am noticing that you are looking of the MTBF of embedded processors, for your particular question we recommend referring our Embedded Intel® Core™ community (https://forums.intel.com/s/topic/0TO0P00000018NGWAY/embedded-intel-core). Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
jzhao54
​Hi Leonardo,
thanks for your replying, but i am a little confused on the purpose of the link you shared.
is there anyone will answer my question here?
Junjie
CarlosAM_INTEL
Hello, @jzhao54​:
It is important to let you know that the Mean Time Between Failure (MTBF) is simply the inverse of the failure rate for an exponential distribution while the Failure in Time (FIT) rate is 10^9 x failure rate
MTBF = 1/failure rate
Example:
If FIT = 15.1, then MTBF = 10^9/15.1 = 66225165
The FIT values are stated in section 4.3, on page 9 of the Production Release Qualification (PRQ) Report of these processors that can be found at the following website:
http://qdms.intel.com/prq/prq.aspx/2F292E05-3E73-4BFD-91C6-97734F92AAD1/PRQ_2d224.pdf
On the other hand, the Junction Temperature (Tj) of these processors is stated in section 4.2, on page 8 of the provided PRQ.
Reliability is affected by the environment the equipment is operating, in particular temperature plays a degrading role in component life. MTBF Predictions are based around the principle that temperature accelerates reliability degradation.
@Mæcenas_INTEL​.
jzhao54
Hi Maecenas,
it is just what I need, great thanks for your help!
Junjie
