Hi, I was hoping the minimum operating limits for the Intel i9-13900TE component could be provided. The datasheet lists the maximum operating and junction limits of 100C but does not state a minimum temperature. Thank you for your help!
Hi @thermnerd
Sure, the operating Junction Temperature Range for this CPU is: 0°C to 100°C
Jaime L.
Hi @thermnerd
Jaime L.
What might the min/max survival limits be for the Intel i9-13900TE component? Thanks for the help
Hello @thermnerd,
I think you can use the MTBF.
https://www.intel.com/content/www/us/en/support/programmable/articles/000078299.html
You can check the FIT from the PRQ for the 13900TE, from document #773061.
You will need a Premier account in order to get access to it.
