Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1332 Discussions
Portwell Announces New High-Performance PEDA-S1530 Panel PC Series Based on Ultra-Low-TDP 4th Generation Intel® Core™ Processors (Formerly Codenamed Haswell)
Portwell Inc., a world-leading innovator in the Industrial PC (IPC) market and a Premier member of the Intel® Internet of Things (IoT) Solutions Alliance, announces PEDA-S1530, a new high-performance and fan-less panel PC with five-wire resistive touch screen. The Portwell PEDA-S1530 Panel PC is powered by the ultra-low-TDP Intel® Core™ i3-4010U (1.7GHz) processor and includes 4GB DDR3L SO-DMM memory which can be upgraded to 16GB.
"The fan-less design ensures silent operation, improved reliability and reduced maintenance costs." says Penny Liao, Portwell's product manager. "Equipped with a 15-inch True Flat five-wire resistive touchscreen and a resolution of 1024 x 768, the PEDA-S1530 comes with an IP65 rated front panel, and is housed in an aluminum bezel with anodizing coating. This allows PEDA-S1530 to operate under harsh environments," Liao adds. In addition, the PEDA-S1530 features all required interfaces for industrial application: 1 x HDMI port, 1 x Display port, 2 x Gigabit Ethernet, 2 x USB 2.0, 2 x USB 3.0, 1 x RS-232/422/485 port, 3 x RS-232 ports, 1 x 2.5" SATA HDD or SSD, 1 x mSATA device and a Compact Flexibility from Embedded eXtension (CFEX) slot for storage capacity. Two SMA Antenna holes provide optional WiFi and 3G function via Mini-PCIe add-on card and SIM card reader.
Modularization is the major design concept for Portwell's PEDA Panel PC series, which enables the panel PC unit separated into an independent "PC box" and a "touch panel display". As a result, users can choose different sizes of panel from 12.1˝ to 21.5˝ to integrate with the "PC box" by customized cabling. PEDA-S1530 also includes a friendly, tool-less installation design for<span lang="EN-US" style="fo...
