Portwell, Inc., a world-leading innovator in the Industrial PC (IPC) market, today announced the Portwell WADE-8015, a Mini-ITX form factor embedded system board, which adopts the 4th generation Intel® Core™ processor family (formerly codenamed "Haswell"). The 4th generation Intel Core processors drive the Portwell WADE-8015 to have higher performance and more functional expansion flexibility. Portwell 's WADE-8015 creatively extends the motherboard design concept at the horizontal level and increases combination options for application-specific functions.
The Portwell WADE-8015 is based on the Intel® Q87 chipset and the 4th generation Intel Core processors in an LGA1150 socket supporting two-channel DDR3 long DIMM sockets and PCI Express Gen 3 to provide great data transferring bandwidth for improving graphics performance. Moreover, the enhancement in flash playback, rich 2D/3D graphics quality, security and power efficiency enables a fascinating visual experience in a variety of market segments such as Retail, Military, Medical, Industrial Automation and Digital Security Surveillance.
Portwell's WADE-8015, featuring flexible expansion interface, provides a brand-new solution under available resources and limited mainboard space. Different from existing Mini-ITX boards in the marketplace, which utilize a riser card to increase functional interfaces or additional PCIe/PCI slots, the Portwell WADE-8015 leverages an extension board to furnish a flexible platform that facilitates multiple functional expansion choices. Bridging PCIe signals through the Gold Finger to the extension board, WADE-8015 can easily support the functions on a two-slot-added FlexATX or three-slot-added Micro ATX motherboard. This expansion mechanism also supports other interfaces transmitted via specific circuit design and component selection. Therefore, Portwell can quickly make ready a customized solution with additional, project-required features, such as LAN, Mini-PCIe, etc.
The Intel Q87 chipset continues to work on the edge of innovation with a new architecture to deliver quality, performance, and industry-leading I/O technologies on most of the platforms powered by the 4th generation Intel Core processor family. WADE-8015 is the first Portwell off-the-shelf product utilizing the Intel Q87 chipset on the Mini-ITX platform. Designing with the 4th generation Intel Core processors manufactured on the latest 22nm process technology, Portwell has taken the advantage of the powerful and energy efficient CPU to create a series of products that provides smart security, high-level management, and intelligent performance for industrial platforms.
The WADE-8015 offers lots of features including SATA storage, up to 6 Gb/s, via four SATA interfaces (two SATA III and two SATA II), supporting RAID 0/1/5 and 10 modes. The latest PCIe Gen 3 (one PCI Express x16 slot from CPU) delivers high speed and bandwidth, up to 8 GT/s. In addition, it features the latest USB 3.0 high speed transmission technology which supports 10 USB ports (four USB 3.0 ports on rear I/O and six USB 2.0 pin headers on board); two long-DIMM memory slots for DDR3 SDRAM, up to 16GB; and triple displays via VGA, HDMI and DP, which support both clone mode and extended mode. The Portwell WADE-8015 is also equipped with dual Gigabit Ethernet connectors and a Mini-PCIe interface with mSATA signal which provides customers with flexible choices for designing with devices for their storage-demanding applications. And again, the special extension-board design enables great flexibility and expandability for customized system integration.
Info Link:http://www.portwell.com.tw/products/WADE-8015.html http://www.portwell.com.tw/products/WADE-8015.html
