Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Questions about dpdk kni example
祥曾1
Hi everyone,
While running the DPDK 17.02 kni sample application,I found machine can not surf the Internet but ping other LAN machines is ok.
My Env:
CentOS 7.2 x86_64
gcc version 4.8.5
Intel(R) Xeon(R) CPU E5-2620 v3 @ 2.40GHz (24 core)
Intel Corporation Ethernet Controller 10-Gigabit X540-AT2
I did the following:
1. Bind nic with DPDK driver successfully.
2. insmod rte_kni.ko
3. Start the kni application
./build/kni -c 0x3 -n 2 -- -P -p 0x1 --config '(0,0,1)'
4. Assign the ip address to vEth0
ifconfig vEth0 192.168.44.129 netmask 255.255.255.0
5. Assign the MAC address to vEth0
I would like to know whether kni sample can ping the Internet ok, if not, how should I use of dpdk with kni?
Aland
Adolfo_S_Intel
Hello Aland,
Have you tried contacting the DPDK support forums?
Please try using the following mailing list: mailto:[email protected] [email protected]
Also please make sure that you are working with one of the supported NICS: http://dpdk.org/doc DPDK doc
Adolfo Sanchez
祥曾1
Hello Adolfo,
I really appreciate your help.
I will try to contact the DPDK forums.
Aland
