Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1329 Discussions
[Rangeley] How to disable Rangeley internal UART?
JLee169
Hi All,
My platform is Rangeley + winbond w83627DHG, and BIOS is cioreboot mohonpeak +Intel FSP,
according platform layout I need to disabe Rangeley uart and enable w83627DHG COMA, but follow below
implement procedure, the data can't output 3f8h, look like the 3f8h space have conflict, but on AMI
BIOS is working fine,have any one know it? Am I loss some step? thanks.
1. Disable INTEL internal UART 0,1F,0 +80 ----> 00
2. Enable 83627 COM A
1. setup muti function pin
2. initial COM A to 3f8h irq4.
James
Adolfo_S_Intel
Hello James_Lee
I was checking the datasheet for the Rangeley: http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/atom-c2000-microserver-datasheet.pdf http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/atom-c2000-microserver-datasheet.pdf
I see that you are writing to B:0,D:0x1F (31), F:0+80 But the UART_CONT is the Bus:0, Device: 30 (0x1E), Function:0, Offset 80. (See the datasheet, Vol.2, page 464)
Hope this information is useful to you.
Adolfo.
Adolfo_S_Intel
Hello James_Lee
We are investigating your issue, and will contact you when we have useful information for you
Adolfo.
Adolfo_S_Intel
Hello James_Lee
Adolfo.
JLee169
Hi Adolfo,
The datasheet page 463/509 device is 31, on page 464 is 30.
and checked ami code is device 31, from "RW" tool to scan
LPC(ISA) device is on 0,1f,0, 0,1E0,0 is empty...
However I have test to disable 0,1e,0 also can NOT to fix this issue.
Adolfo_S_Intel
Hello James
Enable 83627 COM A
I'm not sure if I understand clearly the point number 2.
Could you clarify the following questions?
1) When you talk about 3F8h are you talking about the Fixed I/O Map that is on table 10-4 of the datasheet?
2) Are you enabling IRQ4 on the Windbond?
3)Are you using the APIC or the internal PIC?
4)Did you enabled the SERIRQ interruptions in the Rangeley?
Adolfo
JLee169
Hi Adolfo,
Happy new year, thanks you respond so quickly, please see below my answer,thanks.
yes. AMI also use 3F8/IRQ 4 on w83627.
yes, same AMI.
yes, coreboot use APIC.
yes, coreboot default enable SERIRQ, and continue mode.
Adolfo_S_Intel
Hello James_Lee
Sorry for the long delay
I'm consulting your issue with our Intel Division.
In the meantime could you please answer the following questions to gather more information about your issue:
Could you please tell me what registers are you configuring in the W83627DHG, and what values are you using?
What happens when you try to read from 3F8h?
Does AMI BIOS also use the APIC or the PIC8259?
Do you know if the W83627DHG is being positively decoded, or substractively decoded?
Do you have access to the content of the CPU registers? If yes could you please compare the content of the following registers: LPCC, IRQEN, SCNT, OIC,
IR31,PIRQA-PIRQH, when using AMI BIOS and when using Coreboot?
Adolfo
JLee169
Hi Adolfo,
please see below my answer, thanks.
James: globel registers 24:clock select. 29: mutipin select to select UARTA pin, other 24~2E same AMI .
UARTA 30:enable 60/61: address 3F8 70: IRQ 4
these parts is same AMI.
James: always is value 08h.
James: AMI is PIC8259.
James: no, I dont know , datasheet no write this.
James: I have follow AMI to fine tune these resisters, also can not to fix issue.
So far on BIOS post time no console message out, and on DOS mode also can NOT R/W 3F8h,
Best Regards
James
Adolfo_S_Intel
Hello James_Lee
Sorry for the delay.
So far the only difference I have noticed in your setup is that Coreboot is using the APIC, while AMI Bios is using the PIC controller.
Is it possible to you to try configuring the Coreboot to use the PIC, and test the results?
Adolfo.
JLee169
Hi Adolfo,
Issue already fixed, I borrow a scope, and measure w83627pin waveform,
I find the 48M clock is no input.
So Rangeley disable UART code is right.
Superio UART implement code is correct.
Clock generator coding is wrong.
so UART is work fine now, thank your help.
Best Regards
James
Adolfo_S_Intel
Hello James_Lee
I'm glad that your issue has been solved.
And thanks for taking the time to come back to us and explain how you solved your problem, feedback from users of the community is really important and can help people with similar issues in the future.
Adolfo.
