Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1416 Discussions
System Management Mode (SMM) questions - need help
JFlan
Hi..
Just joined the group as I was told this would be an excellent location for asking my question(s)..
I own a '98 vintage Tektronix logic analyzer that used a custom controller board which ran Win95/98
and made use of a 133 MHz Pentium. The analyzer supported the 'soft - off' power down method
which would force a safe windows shutdown, followed by a hardware power off. We all expect
this nowadays in the computers of our time. When I upgraded to Windows 2000, this soft power
off mode ceases to work. I've discovered the reason and I need to make some changes
to the SMM interrupt handler located in bios.
Finally, my question:
In order to shutdown my logic analyzer system properly, I need to make a Win2000 system call.
Is this allowable from within SMM? The documentation that I have found on the Internet in regards
to SMM is not clear. If this is not possible to make a system call, what would be a recommended
method of achieving what I need? Could I create a process which would initiate when I exit SMM?
Any help that you can offer would be great. I have yet to find anyone with any experience in
the 'nuts-n-bolts' of system management mode..
thanks
Jim
