Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1311 Discussions
[TESTCASE] i9-12900TE crashes hard when E-cores in Performance (H/W p_state) mode
JBourquard
Model : 12th Gen Intel(R) Core(TM) i9-12900TE
Microcode: 0x2e
I found a testcase that crashes the CPU, if (and only if) efficiency cores are set to "performance" hardware p_state mode.
This only happens for E-cores. P-cores do not exhibit this problem. And this is *not* a thermal issue.
This was reproduced on a Karbon 803 from OnLogic, with two different i9-12900TE CPUs.
OS: Linux (many different kernels, including latest 6.5.1). Also happens on Ubuntu Server 22.04.3 with latest updates.
This problem never happens with regular CPU/RAM stress testing tools. So I built a bootable testcase that can be launched in 2 minutes:
[!! Pulled my link for security reasons]
(can take a few hours before the crash happens).
The problem *could* be in Linux hardware p-states driver, but it can also be a microcode bug!
I already contacted OnLogic for support and they replaced the CPU, but of course the problem persists.
Could someone please direct me to Intel for further investigation?
Thanks in advance,
Joël
JBourquard
Hi @Jaime_Lizarme , @DeividA_Intel ,
Thank you for your response, much appreciated.
The PSIRT is taking care of the case now, so we can probably close this topic.
Thanks again!
DeividA_Intel
Hello JBourquard,
We would like to inform you that we have a forum for these specific issues and products, so we are moving it to the "Embedded Intel® Core™ Processors" forum so you can get better support for this matter.
https://community.intel.com/t5/Embedded-Intel-Core-Processors/bd-p/embedded-core-processors
Deivid A.
Jaime_Lizarme
Hello @JBourquard ,
We sent an email to the address associated with this account with information that may help you.
Jaime L.
JBourquard
Thanks again!
