Hello
The Use Conditions part of Intel Core i7-14701E Processor is different in Intel Ark and Quick Reference Guide (doc#: 615485).
Intel Ark: Embedded Broad Market Commercial Temp
Intel QRG: PC/Client/Tablet
Which status are correct?
Hello @Taka1006 ,
The Intel Core i7-14701E Processor belongs to the Embedded marketo, so you need to use the "Embedded Broad Market Commercial Temp"
Jaime L.
Thank you for your replay!
However, I have more question.
Intel ark status of Intel Core Processor 201E ~ 251E skus are "vertical segment" is Embedded, and "Use conditions" is PC/Client/Tablet.
https://www.intel.com/content/www/us/en/products/sku/242803/intel-core-7-processor-251e-36m-cache-up-to-5-60-ghz/specifications.html
If your assertion is correct, then is Intel Core Processor 201E~251E status of Intel Ark/QRG also wrong?
Hello @Taka1006 ,
The 201E ~ 251E processors are different processors from your original question, so to better keep track your question, please raise a new thread for your new inquiry.
Jaime L.
Hello Jaime_Lizarme
I didn't want the answer of 201E~251E status.
In my last post, I wanted to confirm whether your assertion was correct.
"It belongs to the Embedded marketo, so you need to use the "Embedded Broad Market Commercial Temp""
I think that use conditions status of Intel QRG is generally more accurate.
however, I don't understand why use conditions status is not Broad Market Commercial Temp in 14701E.
and I can't easily believe your assrtion because there are 201E~251E cases.
I will try to contact the email address on Intel QRG.
Thank you for your cooperation.
