Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
The remote end hung up unexpectedly
wmirr
Hi.
I am building galileo follow:
http://www.malinov.com/Home/sergey-s-blog http://www.malinov.com/Home/sergey-s-blog
my host is ubuntu 12.094
I have build it successfully once.
but last night, i want to restart the whole process. when I execute setup.sh, errros comming:
watermirror@WM:~/galileo/meta-clanton_v1.0.0$ ./setup.sh
Running: git init
Initialized empty Git repository in /home/watermirror/galileo/meta-clanton_v1.0.0/poky/.git/
Running: git remote add origin git://git.yoctoproject.org/poky
Running: git fetch origin --depth=3 tags/dylan-9.0.2:tags/dylan-9.0.2
fatal: The remote end hung up unexpectedly
fatal: protocol error: bad pack header
Traceback (most recent call last):
File "setup/gitsetup.py", line 131, in
main()
File "setup/gitsetup.py", line 117, in main
run_command('git fetch origin --depth=%s %s' % (opts.depth, fetchspec))
File "setup/gitsetup.py", line 65, in run_command
subprocess.check_call(command, shell=True)
File "/usr/lib/python2.7/subprocess.py", line 511, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command 'git fetch origin --depth=3 tags/dylan-9.0.2:tags/dylan-9.0.2' returned non-zero exit status 128
i have tried many ways to fix it ,but failed.
please help me out.
Natalie_Z_Intel
Hello! I've sent this to a few colleagues to see if they can assist you but in the meanwhile, check out https://communities.intel.com/community/makers/ Space: Makers | Intel Communities.
wmirr
Hi, LynnZ.
I think there's some problem with the server. I can execute setup.sh ,but when i run bitbake image-full, new problem came out:
Log data follows:
| DEBUG: Executing shell function do_kernel_configme
| [INFO] doing kernel configme
| [INFO] Configuring target/machine combo: "standard/clanton"
| [INFO] collecting configs in ./meta/meta-series
| mv: target `3.8.7' is not a directory
| creation of pre-processed config data failed
| config of "standard/clanton" failed
| ERROR: Function failed: do_kernel_configme (see /home/watermirror/galileo/meta-clanton_v1.0.0/yocto_build/tmp/work/clanton-poky-linux-uclibc/linux-yocto-clanton/3.8-r0/temp/log.do_kernel_configme.30614 for further information)
ERROR: Task 348 (/home/watermirror/galileo/meta-clanton_v1.0.0/meta-clanton-bsp/recipes-kernel/linux/linux-yocto-clanton_3.8.bb, do_kernel_configme) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2646 tasks of which 2612 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
by the way, the bsp file i used is :
Board_Support_Package_Sources_for_Intel_Quark_v1.0.0.7z,
download from https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23197 Download Center
not Board_Support_Package_Sources_for_Intel_Quark_v0.7.5.7z
what could i do now?
thanks.
