Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1138 Discussions
Whether Haswell products contain REACH SVHC 224 substances
AEC1
Dear Sir,
Please tell me about the following questions.
Do the following CPUs(Haswell) contain REACH SVHC 224 substances?
I referred to MDDS (Doc#706998) and DCL (Doc#608983), but MDDS is old and I could not find all of them.
Specifically, I do not know if the following substances are contained.
・1,3-propanesultone CAS#1120-71-4
・4,4'-isopropylidenediphenol (BPA) CAS#80-05-7
・Lead CAS#7439-92-1
・Perfluorobutane sulfonic acid (PFBS) and its salts (ECHA Candidate List Date 16.01.2020)
Target CPU
i5-4570TE  CM8064601484301S R17Z  MM#929226
i3-4330TE  CM8064601484402S R180  MM#929227
G1820TE   CM8064601618705S R1T6  MM#932857
Kohei Kato
CarlosAM_INTEL
Hello, @AEC1:
You should follow the procedure stated on the following website to help you with the REACH Regulations and Substances of Very High Concern (SVHC) information for Intel® Products:
https://www.intel.com/content/www/us/en/support/articles/000059792/programs/intel-corporation.html
@CarlosAM_INTEL.
AEC1
Dear Sir,
Thank you for your reply.
MDDS(Doc#706998) and REAECH DCL(Doc#608983) are already referred to.
REAECH DCL contains the following description.
The European Chemicals Agency released the latest candidate list of SVHC on June 10, 2022,
bringing the total number of substances to 224. To the best Intel’s knowledge, except for the
seven SVHC listed in Attachment 1, the other SVHC are not present above 0.1% by weight in any
article of Intel’s products.
Attachment 1 - List of SVHC present above 0.1% by weight in article of Intel’s products
(Please refer to P3(Doc#608983).There are seven substances in all.)
However, MDDS (Doc#706998)  was updated in 2015 and does not list the following substances.
These substances were added to REACH after 2015.
・Lead CAS#7439-92-1
Please let me know if the above is included in the target CPU.
CarlosAM_INTEL
Hello, @AEC1:
Thanks for your reply.
We sent an email to the address associated with this account with information that may help you.
@CarlosAM_INTEL.
