Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
eepromARMtool
GShen9
I'm look for the eepromARMtool source, I need to program my new hardware with i210 on an ARM plat , please send the tool and related data to my E-mail :mailto:gongshengli@hnlx.com.cn gongshengli@hnlx.com.cn (Already registe the EDC).
Gong
CarlosAM_INTEL
Hello gong ,
Thank you for contacting the Intel Embedded Community.
We have contacted you via email.
By the way, your privileged account has been approved.
Carlos_A.
CarlosAM_INTEL
Hello gong,
This tool can be sent to you if you have an Embedded Design Center (EDC) Privileged account. In order to request an upgrade from your Basic EDC account to Privileged, go to/www.intel.com/content/www/us/en/embedded/embedded-design-center-support.html http://www.intel.com/content/www/us/en/embedded/embedded-design-center-support.html and click on "Manage Your Intel Profile" found in the "Manage Your Account" section of the page. From there you can request an upgrade. The application can be found at:
/www-ssl.intel.com/content/www/us/en/forms/intelligent-systems/registration-po.html https://www-ssl.intel.com/content/www/us/en/forms/intelligent-systems/registration-po.html
In order to help you with the EDC account update process, we suggest you use a business email address to evade any inconvenience. Please avoid the free email provider's address (such the provided by Hotmail, Gmail, yahoo, or others).
We hope that this information may help you.
Carlos_A.
CarlosAM_INTEL
Hello gong ,
Carlos_A.
AFana
We have developed a board with a CPU ARM i.MX6 DualLite and an Intel 82574L as Gigabit Ethernet Controller.
The OS is Linux openSUSE 13.1.
Formerly we programmed separately the eeprom associated to the 82574L.
Now we would like to program this eeprom through the 82574L.
It seems that Intel has a tool eepromARMtool able to do that.
I have a privileged account; what must I do to download this tool ?
Thank you for the help.
Dranaub.
CarlosAM_INTEL
Hello, Dasnim:
In order to help you, we will contact you via email.
Carlos_A.
LLu4
We have developed the i210-AT with nVidia SOC which is use Linux OS. And we have to program data into a blank EEPROM.
It seems that we need a tool eepromARMtool. Where and how we are able to download the eepromARMtool.
Thanks for your great help
Luke
CarlosAM_INTEL
Hello, Luke_Lu :
Carlos_A.
LLu4
Hello, Carlos A:
Thank you for your support.
Now, I get "Bus error" message while try to dump data from NIC use command "sudo ./eepromARMtool –dump –NIC=1"
CarlosAM_INTEL
Hello, Luke_Lu
Thank you for your update.
In order to better understand your previous communication, could you please clarify us if the NIC card related to the cited situation has been designed by you or by a specific company? If it is a third party design, could you please give us all the information related to it?
By the way, could you please confirm if the affected board has been reviewed by Intel?
Please give us all this information to have a better idea of this problem.
Carlos_A.
rhsie6
Hi Carlos and Luke,
I have the same problem with "Bus error" occurs when i try to dump nic1.
I have tried to
ReadReg(dev, 0x5b48) , return 0
ReadReg(dev, 0x5b50) , return 0 << in Ver 0.6.7, it is [SWSM]
ReadReg(dev, 0x5b58) , return 0
ReadReg(dev, 0x5b5c) , "Bus error" then breaks << in Ver 0.6.7, it is [SW_FW_SYNC]
ReadReg(dev, 0x5b60) , return 7018000
i execute those ReadReg just in AcquireNvmI210(); before original
SyncVal = ReadReg(dev, SW_FW_SYNC);
Can you help me to find out why i got "Bus error" at address [SW_FW_SYNC] ?
CarlosAM_INTEL
Hello, reifan:
We suggest you verify the way that the memory map is accessed because the bus errors are generally solved by checking the memory map. It is probably that it is accessed the wrong memory and hence the wrong register or illegally accessing memory assigned to some other function.
We hope that this proposal is useful to you.
Carlos_A.
VTrud
I work with a ARM i.MX6 and an Intel i210 Gigabit Ethernet Controller.
It seems I need eepromARMtool.
You should create an easy to find page where developers can get the source code.
Vincent
CarlosAM_INTEL
Hello, vtrudell:
The information that you need is classified as confidential.
Due to this fact, in order to obtain it please follow the suggested procedure stated in this thread, specifically on our communication of the past August 22nd, 2016 9:29 AM.
Carlos_A.
VTrud
Hi Carlos_A
Both links are broken (404 error).
I tried to follow the procedure and found the website myself. https://www-ssl.intel.com/content/www/eu/en/secure/profile/profile.html https://www-ssl.intel.com/content/www/eu/en/secure/profile/profile.html
However I cannot proceed any further. I keep being asked by login credentials even though I am logged in already. Entering my creds again just brings back the login page again and again.
Vincent
CarlosAM_INTEL
Hello, vtrudell:
Thanks for your update.
In order to request an EDC Privileged account go to http://www.intel.com/content/www/us/en/embedded/embedded-design-center-support.html. Then click on "APPLY NOW" found under the heading, "Apply for extras with privileged access to the Intel EDC¹".
By the way, in the cited website you may found the Account Assistance options to solve your account problems.
Carlos_A.
VTrud
Now that I have the privileged account, can you send me the code?
CarlosAM_INTEL
Hello, vtrudell:
Thanks for your reply.
We will contact you via email to help you.
Carlos_A.
SMich6
We developed one board build on ARM architecture and using an Intel i210 controller.
Could you provide us eepromARMtool.
Sylvain
CarlosAM_INTEL
Hello, sylvainmichelet:
Carlos_A.
DKlet
We are in need of the EEpromArmTool for an i210 design. Could you send that to me? I do have a privileged account already.
Thank you!
CarlosAM_INTEL
Hello, Daniel_K :
Carlos_A.
