Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
i7-1186GRE_ cTDP _ fix CPU frequency
flykevin0021
I have question about cTDP configuration and use case in I7-1186GRE design. We are consider to use I7-1186GRE for new project. and the system is required running stable in high cpu frequency.
1. fix CPU frequency as 2.8Ghz that is base frequency of cTDP-UP mode :
    - We want to get review and confirm for this use case from Intel. Can you provide any advise and risk point for this use case?
    - Please guide us how to config to fix CPU frequency as 2.8Ghz. It looks that we can set PL1 and PL2 CPU frequency and disable turbo mode. if so, we can set PL1 and PL2 as cTDP up frequency?
We want to disable turbo mode and running the system as cTDP UP mode always. this is required for stable system to avoid any corruption happening during cpu/power management work.
Thank you for your help.
CarlosAM_INTEL
Hello,  @flykevin0021:
The information that may help you is accessible when your account is an Intel Developer Zone Premier account. Due to this, you should update it by filling out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
Your business email address is needed to avoid any inconvenience. The free email provider's address (such as the one provided by Hotmail, Gmail, Yahoo, or others) is not the proper one for this process. This information and more details can be found on the following website:
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
@CarlosAM_INTEL.
flykevin0021
We have the DZP account. checked as like below. Is there any other issue?
CarlosAM_INTEL
Thanks for your reply.
We have sent an email to the address related to this account with information that may help you.
@CarlosAM_INTEL.
