Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1165 Discussions
i7-4700EQ clock frequency at 2.4GHz. Could you provide more detail about frequency 2.4XXXGhz. Just like 2.4321Ghz.
TWu
CarlosAM_INTEL
Hello, @TWu​:
In order to help you, we want to address the following question:
Could you please clarify if this thread is related to a technical problem? In case that your answer is affirmative, please give a detailed description of the issue.
We are waiting for your reply.
@Mæcenas_INTEL​.
TWu
My customer want to know the detail frequency about i7-4700EQ.
Could you provide the detail frequency?
CarlosAM_INTEL
Hello, @TWu​:
Thanks for your reply.
In order to better understand your request, could you please clarify the meaning of "detail" on your previous messages?
We are waiting for your answer.
@Mæcenas_INTEL​.
TWu
Hi Mæcenas
There is no issue on  i7-4700EQ.
We just want to know the frequency information.
Do you have the information or not?
CarlosAM_INTEL
Hello, @TWu​:
The following yellow highlighted information may answer your question:
This information can be found at the following website:
https://ark.intel.com/content/www/us/en/ark/products/75469/intel-core-i7-4700eq-processor-6m-cache-up-to-3-40-ghz.html
@Mæcenas_INTEL​.
TWu
Hi Mæcenas
 i7-4700EQ base frequency is 2.4000 GHz ?
Am I right?
CarlosAM_INTEL
Hello, @TWu​:
Based on the information provided on our last communication, you are correct. Also, please keep in mind that the operation frequency should be in a range from Base value to Max Turbo Frequency as you may notice in the yellow highlighted info provided on our previous communication.
Please let us know if you have any updates or questions.
@Mæcenas_INTEL​
TWu
Hi Mæcenas
From technical point of view and considering customer applciation, this answer isnot acceptable as this frequency is driving their real time cycles (Criticity of 20ms).
As all fluctuation are deactivated inside the BIOS (speedstep, reduction of frequency from temperature, ...), can we get a more accurate answer?
Is there a manner, under WES2009 or RTX, to read this frequency directly from a register of the CPU?
CarlosAM_INTEL
Hello, @TWu​:
We have contacted you via email to give you some suggestions that may help you.
@Mæcenas_INTEL​.
