Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
CELO TEST OF I350-AM2
jayhsu
After onboard lan (I350-AM2) celo test, linking 10m speed show fail
But i can connect to the internet on 10m/100m/1G ok.
Have idea what cause the test failed?
  • What is the model of the server where the ethernet adapter is embedded?
AMD platform, and use I350 on board.
  • Can you please share with us the link to the tool being used and the steps?
Resource & Design Center Sign In (intel.com)
Step: celoe.efi  /sendresp 1 2  /stopfail  /loop 10
  • Was it working before or is this the first time running the tool?
No, this was the first time.
  • Is this the only issue with the adapter (Test)? Does it work fine?
CarlosAM_INTEL
Hello, @jayhsu:
We sent an email to the address associated with this account with information that may help you.
@CarlosAM_INTEL.
jayhsu
Hi Carlos,
Thanks for your reply. Could you discuss with Roger(rogershih@msi.com)?
He understand the detail situation.
CarlosAM_INTEL
Hello, @jayhsu:
We suggest following the suggestions provided in the email sent to the address associated with this account.
@CarlosAM_INTEL.
jayhsu
Hi Carlos,
I didn't get information or solution from the letter.
I have tried any way the problem still exists.
CarlosAM_INTEL
Hello, @jayhsu:
Thanks for your update.
We sent again an email to the address associated with this account with suggestions that may help you.
We suggest review your spam or not desired inboxes to verify that this and the previous emails can be found from your side.
@CarlosAM_INTEL.
